Question about Texas Instruments TI-84 Plus Calculator
Every time I go to graph any equation, I get an error: invalid dim message. How do I fix it?
Posted by d0lf1n25 on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" (the F1 key) and then select 4:PlotsOff.
Posted on Oct 17, 2010
Fix the ERR:INVALID DIM message on my TI-84 plus, please.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd, STAT PLOT , and
Mar 26, 2012 | Texas Instruments TI-84 Plus Calculator
So on my graphing calculator i put my equation x^3-x^2-10x-8. then i hit graph and it says err:invalid DIM.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd then stat plot, and then select 4:PlotsOff. By the way it is easy to graphing function y=x^3-x^2-10x-8.
See captured images: full graph and detail of the left side max
As you can see this function have zero values in the points -2, -1 and 4
Mar 04, 2012 | Texas Instruments TI-84 Plus Silver...
What is the meaning of the error "invalid axes"?
This is problem with graphing differential equation. Invalid Axes error occurs if Axes=TIME or if t(time) is set as a CUSTOM axis. This is important to noticed: if Fields=DIRFLD you cannot plot a time axis. See captured image:
This graph represented differential system of equations y1'(x)=y2(x), y2'(x)=-y1(x) for initial conditions y1(0)=0, y2(0)=-1.Finally, x axes=y1(x) and y axes=y2(x)
Feb 08, 2012 | Texas Instruments TI-89 Calculator
When attempting to solve graphing equations GETTING graphing error says INVALID DIM
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If this doesn't do it, please reply to this post and give a sample equation that causes this error.
Sep 09, 2011 | Texas Instruments TI-83 Plus Calculator
Invalid dim, i have been graphing equations and all of a sudden it pops up with that error message
If that doesn't do it, please reply to this post specifying the equation(s) you're trying to graph.
Nov 03, 2010 | Texas Instruments TI-84 Plus Silver...
TI-83 Plus Calculator: My TI-83 reads "INVALID DIM" when I try to graph a...
May 17, 2010 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus Calculator: I am trying to graph an equation and I get the "ER...
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.
If the message appears in another context, it sure would help knowing the context of the error.
May 07, 2010 | Texas Instruments TI-83 Plus Calculator
Cannot graph invalid dim error
This error show up when you are graphing out of the plot menu. If you are not graphing data points from list menu, you need to turn the plots off. In the y= screen, you will see the words plot 1, plot 2, etc across the top of the screen. If one of the plots is highlighted (black box over the words), you need to turn it off. This can be done by arrowing up and highlighting the box and pressing enter. When you arrow back down, the plot should be off and you will be able to enter an equation in the y= lines and graph.
If you are graphing from the plot menu, this error lets you know that one of the lists you are graphing is longer than the other.
Another way to fix the problem is to reset the calculator by pressing 2nd button then plus sign then 7 then 1 then 2. This will reset the calculator however if you are graphing from lists, your data will be erased. Hope this helps.
Oct 02, 2009 | Texas Instruments TI-83 Plus Calculator
ERR: INVALID DIM (That's the error message I receive every time I try to graph an equation)
[2nd][MEM][7:Reset][1:All ram][2:Reset] [ENTER]. Screen shows RAM cleared. Clear the screen and use [Y=] to enter the functions you want to graph.
Hope it helps.
Sep 27, 2009 | Texas Instruments TI-84 Plus Calculator
INVALID DIM error! help me!
Here is what the manual says
INVALID DIM : The dimension of the argument is incompatible with th current operation. (As dimension of a matrix, a list).
You can tell us more about what your were trying to do, we may able to help. Reset memory to default, the error may disappear.
[2nd][MEM][7][2][2] Defaults set.
Hope it helps.
Sep 02, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
102 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Ekse
Scoee Scoffer
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
