Computers & Internet Logo
Posted on Oct 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a HP NC6120 laptop and am tring to upgrade the RAM, I found one card slot, but, don't know where the second socket is. do you?
joecoolvette
Level 3:
  • Master 5,660 Answers
  • Posted on Oct 17, 2010
joecoolvette
Master
Level 3:
Answers
5660
Questions
0
Helped
2194734
Points
18014
The second Ram Memory slot is under the Keyboard, as our Expert Moderator Ekse has stated.
This is HP Support
  • joecoolvette
    joecoolvette Oct 17, 2010
    Didn't go through.
Ekse
Level 3:
  • Master 13,435 Answers
Ekse
Master
Level 3:
Answers
13435
Questions
82
Helped
3985159
Points
38023
Hello, and thanks for using FixYa.
If the 2nd slot is not in the bottom of the laptop, then you will find it from under the keyboard.
According to HP specifications of the laptop the memory is Upgradeable to 2048-MB maximum (1024-MB SODIMM in slots 1 and 2) So yes the laptop does have two memory slots. It will be under the keyboard.
Please let me know if you require further assistance or if you have any questions.
Thanks,
Ekse
Ram upgrade
no you have to use pc2700 for the pavilion ze2000. Max Memory 2gb (1gb x 2).
2answers
I m trying to upgrade my HP compaq nc6320 RAM MEMORY from 1GB to 4GB, Do i need BIOS upgrade if yes from were i can find the drivers and how can i do it? thanx i am gone wait for respond......
As far as I know, the machine supports 4GB of ram, so you purchase the ram modules from a pc parts dealer and install them inside the machine, removing the existing ram, there are 2 slots, so you need 2, 2GB cards.
You do not require any drivers or bios update.
Windows will need to be upgraded to 64Bit version if you wish to use the full capacity. as normal windows is limited to 3-3.75GB
Further questions? let me know.
2answers
Hello i would like to upgrade my ram (put in 2x 1 gb) in my hp compaq nx6310 but I can't find both slots, could you pls help me out?
The bottom has two user removeable covers. The first covers the hard drive and the second has the CPU, both RAM slots, and the Broadcom wireless card. pierreleg.jpg
I have a laptop of compaq brand whose modle no is presario C700 in which intel celeron microprocessor is installed. 512 MB ram is installed i want to update it 4 improving its speed. i want to setup a...
I found the manual on the net that gives you instructions on replacing components if you're not sure how, it can be found here.
RAM upgrade
The Compaq Presario C700 uses DDR2 Laptop RAM as shown below.
slasher_x_11.jpg The motherboard of the Presario C700 has two RAM slots, one of them will be occupied by the 512MB RAM (running at 667MHz) module you have at present. This leaves one more that can accomodate a DDR2 667Mhz card of up to 1GB or you could get two 1GB DDR2 800MHz (the faster DDR2) cards and remove the 512 leaving you with a wopping 4GB of memory, that'll definately speed it up. Just remember the Presario C700 can only have up to 2GB of RAM so don't go higher than that or Windows will not boot for some reason.
Processor upgrade
The Presario C700 supports any Socket P, Core 2 Duo or Pentiun Dual Core chips. The fastest processor you can get is the Intel T8300 2.4GHz Core 2 Duo Processor with 3MB L2 cache and an 800MHz FSB
For a full list of compatible processors go to page 9 of the user manual found here.
Is there anything you need to do before or after upgrading your memory card in an hp laptop
If this in reference to the Ram Memory module/s, the answer is No.
Things to know about upgrading Ram Memory in a computer.
A) What is the Maximum TOTAL Amount for the computer. (Motherboard)
B) What is the Maximum Amount for EACH ram slot.
C) What Type of Ram Memory does the computer support. (Motherboard)
D) What frequency rate of Ram Memory does the computer support. (Slang for Frequency Rate is 'Speed')
If you have the correct Ram Memory, and are only installing 1 Ram Memory module, be sure to install it in Slot 1. (Also referred to as DIMM 1)
This is the Ram Memory slot the Processor reads first.
If I knew what HP laptop computer this was, such as the Product Number, and I knew what Ram Memory you are installing, I could help you further.
On the bottom of the laptop is a white Service Tag.
P/N = Product Number
(S/N = Serial Number. Do Not give this out online, except to HP Support)
If your problem does not regard Ram Memory, please disregard this solution.
2helpful
2answers
Adding computer memory
The only thing you could do is put in a 256MB module in the slot that you have access to. Only one socket is user upgradable. The second socket is only upgradable by a Dell service center. They would have to install a second 256 module to get you to the 512MB max.
2answers
Laptop will not boot with new ram memory card
Those beeps are code for what is wrong,
go here to see what yours mean:
http://networking.ringofsaturn.com/PC/beep.php
2helpful
2answers
I have a hp compaq nx 6110 notebook, where are both memory slots?
Your Compaq Notebook nx6110 has 2 banks of 1 socket each for a total of 2 memory sockets.
One is under the keyboard. Here is the user guide, read page 5-26 in the manual(page 137 in the reader)
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00471864/c00471864.pdf
You can install up to 2 GB of memory. links that sell the memory:
http://www.edgetechcorp.com/memory/upgrade.asp?cid=28763
http://www.memoryx.net/cobunonxme5.html
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2helpful
2answers
Compaq nc8230 Ram Upgrade
Do a search on this website for nc8230 manual. I just did and found the complete manual loaded with hyperlinks. Follow the step by step instructions and you will find the process relatively straight forward. Essentially what you need to do is loosen a couple of screws in the back, remove the keyboard then remove a plate underneath which will expose the ram module.
Make sure you read the manual though.
Cheers
Grand Canyon Tech
Grand Canyon Tech
