Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Power went out the stove keeps beeping on broil f1 keeps popping up I cannot set the clock turn the beep off getting a major headache
Posted by rodriqueznai on
Anonymous
    New Friend:
  • 22 Answers
Now days the timers ar all solid state , to me sounds like a timer failure or main controll board and timer
Posted on Oct 17, 2010
What causes the beeping sound coming from my Hearthstone propane stove? I bought my Hearthstone propane stove secondhand.
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
I have an amana artc8600 and the error code it has is f1. could you tell what the code means. Also, when i try to turn the oven on no matter what setting it keeps turning off i have to try a bunch of...
HI,
Disconnect power to stove
Gain access to the back of the clock (electronic range control or ERC).
Unplug the pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
Make sure everything is clear and will not short out when power is turned back on.
Turn power back on to stove.
Watch for the F1 and the beep
If you see f1 and hear the beep its the ERC
If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 • Ovens
Error Code F1 displays once in a while. What does it mean?
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
1. Disconnect power to stove
2. Gain access to the back of the clock (electronic range control or ERC).
3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
4. Make sure everything is clear and will not short out when power is turned back on.
5. Turn power back on to stove.
6. Watch for the F1 and listen for the beep.
7. If you get the F1 and beep, replace the ERC.
8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
* ERC - Electronic Range Control
NOTE: Some models incorporate the touch pad and the clock as one part.
Hope helps.
Apr 20, 2011 • Ovens
What could be the problem if F1 code and beeping in GE wall oven/
F1=Touch control pad and or Clock defective.
Jan 11, 2011 • Ovens
Displaying F1 error
4helpful
It displays F1 . Is this a fuse problem and where is the F1 fuse
HELLO THERE
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
1helpful
F1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
F1 error code, beeping
  • Disconnect power to stove
  • Gain access to the back of the clock (electronic range control or ERC).
  • Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  • Make sure everything is clear and will not short out when power is turned back on.
  • Turn power back on to stove.
  • Watch for the F1 and listen for the beep.
  • If you get the F1 and beep, replace the ERC.
  • If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    N
  • OTE: Some models incorporate the touch pad and the clock as one part.
  • Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    4helpful
    F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
    Hi
    F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
    8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
    thank u
    rate me!!!
    F1 signal started today can't turn the alarm off.model kenmore 9114832593
  • Let me know if this doesn't point you to a solution. There are a couple of more things to try.
    Feb 01, 2009 • Ovens
    Top Frigidaire Ovens Experts
    Marvin
    Marvin
    David Shaub
    nu267
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
