Question about RTO Welding Tools
I have a Thermal Dynamics Pac 50. Was working fine. Now all of a sudden I got a tiny spark at the tip, but the spark gap is going crazy. Arcing like hell. Like everything is going back to the spark gap. What causes that??
2 Related Answers
Anonymous
  • 9 Answers
SOURCE: plazma cutter/no arc
The Cutmaster 50 used two different CD "Capacitor Discharge" Boards. The only ones I have seen a lot of issues with were the smaller ones that are 3.5" X 4"
I have worked on several of the them over the last few months. Even though you might see a spark at the spark gap on the board it might not be sufficient to create a pilot arc.
If your air pressure and so forth are correct your issue is most likely the two white capacitors on the CD board.
Posted on Nov 07, 2009
luis_david
David Soto
  • 414 Answers
SOURCE: Thermal Dynamics Drag Gun Pac
Hi:
Your plasma has a start arc pilot inside the machine, this one must be faulty, check your owner's manual and request the part to your nearest welding store. It is easy to replace.
Posted on Jun 26, 2011
What is the spark plug gap on a 4 cylinder 2009 sonata
The spark plug gap is 32...However some spark plug gauges are inaccurate.The round type with the tiny wires are more accurate than others...In any case whatever you use gap it between 30 and 34 it will be fine...But FYI when you buy the plugs they are pre gapped to fit your car...at times they are slightly out of gap because of dropping them while stocking shelves but when you buy them ask the salesman to gap them..Should be no problem...I hopes this helps...Brooks/Metalpoet......
Jun 08, 2014 | Spark Plugs BR4HS Plug 10/BX #3322
How do you monitor the spark gap on DLP BALAST MODEL WD-65733
The spark gap only operates if the set is arcing in or around the lamp.
Nov 24, 2012 | Televison & Video
Thermal Dynamics Drag Gun Pac 10, Push Trigger, Labored Sound, Cuts Off and wont cut or flash arc. Cleaned Air Filter allways, All New Consummables, Allways kept clean, Has a rattle when trigger pressed...
Hi:
Jun 21, 2011 | Welding Tools
The lights are working for power and gas pressure but not the DC arc....BIG Repair problem?????? It a Pak Master 25 Plasma cutter from Thermal Dynamics bought 15 years ago
No, Try changing the tip. The one under thr node cone. If it burns back it will concave and increase the gap between the work and gun tungdten electrode.
Oct 30, 2009 | Welding Tools
Plazma cutter/no arc
check pilot/output board
Sep 05, 2009 | Welding Tools
SPUTTERING WHEN HOLDING 50-60 MPH
Since it ran fine before you "fixed" it, go back over the things you changed. Put the old spark plugs back in it. Double check all spark plug wires and ignition connections. Put the bike in a dark area and run it at night, can you see any arcing anywhere?
Jul 01, 2009 | 2004 Honda VT 1100 C Shadow Spirit
50"samsung capacitor or diode
That is your lamp supply and I believe your talking about the spark-gap. If it is arcing, that's and indication the lamp supply is working but being loaded down by a bad lamp. Unless you can find a used lamp supply and take that one off, you'll have to buy another lamp supply. I have never had to replace a spark-gap yet. I hope you didn't accidentally break it.
Apr 28, 2009 | Samsung HCM4215W 42" Rear Projection...
Thermal dynamics cutmaster 50 2004 yr.
Check contacts in tip and be sure it is all lubed correctly. If you have good air pressure and flow it should arc after pulling the trigger for about 2-3 seconds.
Sep 27, 2008 | Welding Tools
Poping sound, white specks and what looks like sparks
Possible arcing CRT or possible arcing IHVT part # 239111.
Dec 29, 2006 | Proscan PS50700 50" Rear Projection...
Welding Tools Logo
113 people viewed this question
Top RTO Welding Tools Experts
Bill Boyd
ray gallant
Are you a RTO Welding Tool Expert? Answer questions, earn points and help others
