Freezers Logo
Posted on Oct 17, 2010
I have a Rank Arena BF260 freezer I got from my dad. There is a switch on the front, if it is to the left, there is no icon on it, if it's to the right it has a snowflake icon show. Dad didn't even realise it was there and has no idea about it. What is it for? Thanks Sarah
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1355
Points
It is the fast freeze switch. It keeps the freezer full on even if it gets down to its operating temperature. You will see the yellow or orange light come on. You do this if you want to add some new item in the upper fast freeze compartment. Make sure you turn it off after about 2 hours.
Marty Felber
Level 1:
  • Posted on May 18, 2021
Marty Felber
Contributor
Level 1:
Answers
Questions
0
Helped
1355
Points
Does any one know where to get replacement thermostat for BF260 model?
Anonymous
Level 1:
New Friend:
  • Posted on Apr 05, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1355
Points
I have a rank arena BF 260 freezer which I bought on ebay. Could any one tell me what are the normal settings are for its operation? There are numbers from 1 to 4 on a small dial. what is the default setting for the freezer?
cheer acss
  • Lisa Hendrie
    Lisa Hendrie Apr 01, 2014
    I have a rank arena BF260 that has just recently stopped
  • Lisa Hendrie
    it only has the orange and red lights on can you explain why???
2answers
Why does the orange light come on my Rank Arena Vertical 260 Upright Freezer. Freezer appears to be getting cold but not freezing.
Orange light means it cannot cool properly. I would get it checked by a competent refrigeration engineer.
Feb 11, 2021 • Freezers
2answers
How do I get a ledarndary card because every time I open chests I don't get one clash royale
You can't predict when you will have the legendary cards. Just keep playing and sometimes you receive a legendary card. Good luck!
Clash Royale Guide
Nov 26, 2016 • Freezers
Hotpoint fzfm151p. Bought a year ago. Worked fine up until I moved this month. My dad placed freezer in garage by mistake. Lights flashed (all) ever since it was in there. I've just moved it into the house...
Freezers have an electric motor within to pump the freezer gas around. Its possible the movement has caused a problem. Get ban appliance shop or tech to check it out.
Dec 29, 2014 • Freezers
2answers
Where is th float switch on hoshizaki ice machine
If the machine is a small self contained unit it is normally on the right side of the unit next to the water pump. It has two wires (usually red and black) encased by a grey cover.
Frigidaire upright freezer door will not seal
Hi Chris, this is AP! Thank you for your post.
I understand you are having trouble with the door sealing on your upright freezer. Many times this can be caused by the freezer not being leveled. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems. To level your upright freezer use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, 1/2 bubble higher, so that the door closes easily when left halfway open. I hope this information has been helpful.
There are 3 lights on the front of the Zanussi Freezone. The green one on the left doesn't light up. What does that indicate? The red light on the right is on constantly. Does this mean that the freezer is...
Starting the Appliance
Insert the plug into the wall socket. The green pilot light will illuminate to show that the appliance is switched on. The red alarm light will also illuminate until the freezer reaches the correct temperature.
Alarm Light
The red alarm light will illuminate when the temperature in the freezer is higher than the thermostat setting. This alarm light will illuminate if:
- The appliance has just been started.
- Fresh food has been put in the freezer.
- The lid has been left open, opened frequently or open for too long.
The red light will go out when the freezer has returned to the correct temperature
Dado
1helpful
Yesterday, my dad brought me a working GE upright freezer from his house, transport time about 45 minutes. The freezer was working fine before he left his house, he did tip it little bit to load, unload...
You should try to un-plug the freezer and let it stand up-right over night to re-settle the freon back down inside of the compressor.
The compressor should normally get hot if it is doing it's job right, and there is a starter for the compressor motor (usually it looks like a large capacitor) that could have failed, or the defrost timer (if it has one) could be stuck, and you should be able to see the small dial on the defrost timer slowly turning, and if it does not turn, then replace the defrost timer.
Turn off ice maker
OK I just figured out this must be a european model refrig!
i'm having trouble finding an owners manual in english so looking at the manuals that are in spanish it looks as if there is an on off switch on the 6th sense board. if i'm correct its the icon right above the mode button has picture of one cube next to picture of 3-4 cubes. sorry i led you on a wild goose chase. thx peyton
Jan 26, 2009 • Freezers
Trying to locate componants for the 3 beeps
float switch at front of module to the left of the water pump white plastic with black rubber push on seal
inlet valve at top middle of machine inside small metal holder screwed to top of machine
Top Freezers Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Freezer Expert? Answer questions, earn points and help others
