SOURCE: Washer stopped
Sounds like might be the lid switch... these washers are well know for lid switch problems,
SOURCE: Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
SOURCE: Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
SOURCE: Washing Machine won't stop filling up
Try resetting your water level control. If that doesn't help then set the water level control to the lowest setting and observe if level exceeds that setting. If so, you may possibly have a faulty water level control, or an obstruction in the air dome or water level control hose. This can be a tricky 1 to diagnose for a novice.
SOURCE: Maytag Neptune stops during rinse cycles
Could yoy please explain what the "screen" is?
Thanks,
Carl.
