I have Ropio Easy media Creator 9 installed and have been using it with no problems for almost a year. A few days ago I got an error message saying that "PhotoSuite 9 has encountered a problem and needs to close". After trawling the net in search of an answer I shut down all background programs and tried a repair but the same thing happened again. I tried a complete uninstall and reinstall but still the same problem. So far I've tried both options about 3 or 4 times each with no luck.
Try uninstalling Roxio and the Sonic drives and run Fixit. Then reboot and install Roxio first then the Sonic driver.
If this doesn't work uninstall again as previously, install Roxio and check the CD/DVD if necessary run Fixit then install Sonic driver.
uninstall it or if you cant start your computer reload windows from disc. media creator may be too "big" for your system. pentium 4 min.required,i should think no easy way out if its crashing your computer
This whole error code is a pal around back scratch between Roxio and Windows. To get rid of the "error message" which they created, you have to pay $70.00 for their crapp- axx software that is not even very good in the first place, Too bad Apple is not such junk and expensive, or I would change over. Thanks for really sticking it to us Microsoft!!!
Article Details
ID Number:000131CRProducts:Easy Media Creator 9 Easy Media Creator 9 Deluxe Easy Media Creator 9 Trial Version WinOnCD 9 WinOnCD 9 Trial Version (Not available publicly) Easy CD & DVD Burning ("Vista Compatible" labeled boxes only) RecordNow 9 Music Lab Premier OS:Cause: Through a clerical error, a driver is incorrectly being blocked as incompatible with Windows Vista®. If you do not have one of the above applications, you will need to upgrade to a Windows Vista® compatible version of the software. For Dell Customers
The patch is not intended for a customer base other than Dell. If you do not own a Dell system, it is being offered "as is" and to be used at your own risk.
To download and install the Roxio DLA Update:
Click here for the DLA patch. When the file Download window appears, click Run. Note: If a Security Warning window appears, Click Run.
Follow the installer's on-screen instructions.
When prompted to restart your computer, click Yes.
The computer restarts, and the update is complete
Pleae post here again when you have more issues and ill assist you as long as it takes.
Probably because it was used on another install I bet. Contact support at Nero and tell them that your key was no good. See if they can give you a new one.
