SOURCE: Plasma Display Starting Up
Could be heat build up in the Plasma display unit. Make sure it has the correct space around it for proper ventilation. Also count the number of blinks on the power indicator it is a code for the reason the unit shut down. On the Pioneer PDP-5060HD I have I was getting 12 blinks on the indicator which indicated a tuner issue. Check your instruction book for info on the over heating problem if it continues. You may have a fan out.
SOURCE: Pioneer Elite Plasma TV
Power went out and after it came back on I experienced the same issue. I have not been able to figure out what the problem may be. My elite plasma still won't power on.
SOURCE: My plasma tv has green
unfortunately my solution was to pitch the tv, and had to buy a new one, it was going to cost $1200 and up to fix it. The tech said 5 yrs. for a plasma is about it.
This a factory issue and usually requires service. Most cases it is a bad power supply caused by a surge or powering off and on too fast ... sorry I wish I had better news
SOURCE: Plasma TV moving black and white lines
This is a result of poor conversion of a SD signal on a HD channel. Go into your settings and adjust the h/v settings to move the line off the screen. You can do this with a combination of v-position or vsize.
