It's obsolete this device (means zero support)
HP does not have books on it, now,
so how can you learn what to do?
the only way is at hp, we are not HP here, we are fixya,
no books here.
why not ask the HP forum
ok?
https://h30434.www3.hp.com/
SOURCE: Cannot copy large files to my SD card
Yes , the Activesync connection is not reliable for large files. You really would be best to get a USB card reader, also it would be MUCH, MUCH faster.
SOURCE: iPAQ Backup on SD
Sounds like a potential problem with the SD card -- I'd try reformating the SD card and do another backup... If you still have the error, try another card...
SOURCE: HP ipaq rx3715
Have you tried other SD cards? The box is uncheck for default install folder? Maybe update the device.
SOURCE: Just bought 4GB SD card that hx4700 does not recognise - help pse
Your slot in the iPAQ is a SD slot, not a SDHC slot - therefore it will not read the card. Your PC card is probably a dual reader. The SD cards look the same but are different. Have a read of this...
http://en.wikipedia.org/wiki/Secure_Digital_card
SOURCE: Compaq Ipaq Model # 3950. Password required at
yes, contact hp tech suppory,they should supply you with the correct program to reset the password via usb.
