SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ [email protected] I will send this to you.
SOURCE: Hi, I have a NordicTrack Treadmill, A2050. When
Unplug unit then remove motor shroud then plug unit in then start treadmill your going to use a flat tip screw driver as a stethoscope. Now place the flat on the motor at edge close to the flywheel put your on the handle your ear and you should be able hear if the loud noise form the bearing if not, then repeat procedure on the other end by the fan if the noise is pin pointed on the motor then replace motor, if not originating from the motor the proceed to the front roller.
Use a flash light and observe and locate the font roller shaft so that you can comfortably rest the tip without it slipping on either end of roller.
As before repeat the procedure that was performed on the motor if noise originated their then replace roller if not proceed to rear roller.
Use you flash light and look the adjusting bolts where the end caps are the proceed to insert the screw driver and make contact with the tension bolts listen to each side.
You should locate noise with this procedure take your time and be careful
A) HOW TO LOWER THE TREADMILL FOR USE
1. Refer to drawing 2 above. Hold the upper end of the treadmill with your right hand as shown. Using your left
hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock
knob. Note: You may need to push the handrail to the side slightly.
2. Refer to drawing 1 above. Hold the treadmill firmly with both hands, and lower the treadmill
Watch thsi video:
http://www.youtube.com/watch?v=kDNegYEnrSc
Before folding the treadmill, adjust the incline to the
lowest position. If this is not done, the treadmill may be permanently
damaged. Remove the key and unplug the power
cord.
1. Hold the treadmill with your hands in the locations shown
at the right.
Raise the treadmill about halfway
to the vertical position.
2. Move your right hand to the position shown and hold the
