SOURCE: 1998 honda shadow will not start
Hi and welcome to FixYa,
Initially, a few possibilities you may want to check/explore:
Basically, a general cleanup of the fuel lines, tank and the carbs. Sitting for some time tends to leave varnish like coating on most parts.
Good luck and Thank you for using FixYa. Happy Holidays.
SOURCE: cbr 125 choke problem
It sounds like the choke line may not have been routed correctly when the new one was installed. Remove the gas tank and check to see that the line is not being stretched anywhere along the way AND that the gas tank when re-installed is not stretching the line. The line may have been kinked when installed. Look at the mechanical movement of the choke at the carb. Does it operate freely? Remove the air filter and look inside the center of the carb, (you may need to use a small mirror for this), does it look like the choke is opening and closing properly when the choke is moved on and off?
SOURCE: 98 Honda Valkyrie Tourer, engine stalls
Check vacuum line from #6 intake runner (port side rear cylinder) to the fuel petcock valve. The valve is vacuum operated for safety. It cuts off fuel to the carbs when the engine is shutdown. Hose could be cracked or diaphram in valve is cracked. Easy to inspect the valve.
SOURCE: Valkyrie is difficult to start in cold weather
try using a lighter oil (5W-30, or 10W-30) if your not already using it.
