Question about Peavey CH1 Speaker
I have a pair of Peavey Hysis 2 speakers. At a gig on Saturday night one of the started crackling when loud vocals went through. I set them up in the garage next day and the cab that had been crackling was less clear and muddier sounding than the other one. There was definitely sound coming from the driver and the horn though.
Posted by ronniemayes on
Bill Willard
    New Friend:
  • 48 Answers
You have likely almost but not totally fried a voice coil in your speaker. Most speakers get cooked from underpowering, not from being overdriven. What are the speakers rated for and what are you driving them with?
Posted on Nov 17, 2017
5 Related Answers
Anonymous
SOURCE: Peavey PV215 Speakers
LIGHT IS PART OF SPEAKER PROTECTION CIRCUIT,CAN BLOW,MINE DID TO PROTECT HIGH FREQ DRIVER
Posted on Aug 30, 2008
Verne Koti
  • 476 Answers
SOURCE: Peavey SP5
depends who assembled the speakers as to wheather or not there is any fuse proetection installed.
The drivers are probably gone from the highs because of overloading power surge on the same circuit as the cash register,
or
the crossover is failed.
Cheap fix is replace crossover
expensive fix replace cones of speaker
Best long term protection is to split up the power loading on the stage and surge/spike guard power boards for staging equipment & have resettable fuses installed at the crossobvers or the respective speaker connections.
1.FUSES ARE PROTECTION<
2.THEY BLOW FOR A REASON<
3.PROTECTING THE SPEAKERS<
Posted on Jan 14, 2009
Anonymous
SOURCE: horns don't work on sp2 speakers
I've got Peavey SP2's and SP4XT's and they have one common problem. The 22XT Driver needs replacing from time to time. It could be a power spike, overdriving from amp, over heating or dirt/water in horn. The driver is very easy to replace and costs about $40.00. Remove the horn, carefully lift the horn and disconnect black and red wires. Remember red is always +. Remove driver from horn with socket wrench or socket screwdriver, clean the circular gap on horn with masking tape to remove dirt, hand tighten driver screws, connect red and black wires, carefully set horn back in SP2 enclosure and slowly bring up the power. Also be sure to be very careful when setting the new driver/ coil in the horn. You don't want to damage the coils on the new driver at all!
Posted on Aug 01, 2009
Anonymous
  • 149 Answers
SOURCE: I have a pair of peavey messenger pro 12
they should work and sound awesome as well. your amp should handle the set-up with no problem.
Posted on Aug 09, 2009
Anonymous
SOURCE: I have a pair of Peavey PR15 that I let someone
Active smart fridge/reezer the freezer will not freeze properly and is not automatically defrosting
Posted on Apr 14, 2010
Feedback 3-4 mtres from speakers
Feedback is caused by having the volume up too high or being too close to the speakers. Turn mic down a bit, feedback goes away.
Better speakers and mic will help.
Sep 11, 2014 | AKG WMS 40 Mini Vocal Set Handheld...
I have a cs 1000 amp that lost a channel what do i need to do
Install a patch cord between Graphics in and Graphics out. There is a normally closed contact in the graphics in jack and it will cause loss of signal if it is dirty.
Jun 23, 2014 | Peavey Audio Players & Recorders
I have a Peavey 8600D can I safely run 1 main
When you unload one amplifier you stand the chance of killing the amp's output transistor. If you must use only one speaker, you have to bridge the amps.
Feb 09, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Speaker rattle
Yes, but you need to replace the entire speaker. The 1505 and 1508 use a different magnet though they look similar..
Jan 20, 2014 | Peavey Music
Muffled Sound From Speakers.
Please illuminate me explaining the word "Muffled" means and i will be glad to help you out...
Feb 10, 2013 | JBL *new* Jbl Jrx115 15" 2-way Speaker...
Hi, I would to say thanks a lots to let put some words on yours email box. It's just regarding about how to set up a live band gigs @ outdoor stage in to mixer system. In a mixer setting, i wana know how...
You will need at least a 24 channel mixer to give you spare channels. You also need an active crossover and a snake. The advice you need is too much to include here so I am including some links:http://mixonline.com/live/FixIts/, http://en.wikipedia.org/wiki/Live_sound_mixing, http://mixinglivesound.com/blog/tag/outdoor-concerts/,http://mixinglivesound.com/blog/, and http://www.scribd.com/doc/11435651/Beginners-Guide-to-Mixing-Sound. You may need more monitors than you are planning on and you might consider in ear monitoring.
Aug 22, 2010 | Music
Mic feedback. I sing on a shure beta 58 mic, into a 350 watt peavey amp, into 2 - 200 watt peavey speakers. My band is loud, and I simply cannot get my mic loud enough for them to hear me, without constant...
It sounds as though you are pointing the peavey at the band in a practice situation? If so make sure that each speaker is at about 60 degree angle to either side of the back of the mike (you facing the speakers), most mics reject feedback when the the user is directly in front of a monitor, but Beta 58s' tend to feedback more in that situation. Alternatively (if it is a practice room situation), why not place the speakers behind the band at 60 degrees each and turn to face the band.
Mar 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
I have a pair of peavey impulse 200`s one of the horns just crack`s up and I have to keep it lower than the other to stop it popping.Has it gone or is it fixable cheers.
hey, just picked up a pair of used peavey impulse 200p speakers .. one of the speakers is giving out this very loud high pictched hum (obviously not working). can anyone help or advice, thanks
Mar 01, 2009 | Peavey CH1 Speaker
Connecting cd player to mixer
This should work. I use a similar setup for break music at small gigs. I would check the cable and the output of the unit itself again. .
Feb 21, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Peavey CH1 Speaker Logo
142 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Robert Graf
Marvin
Marvin
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
