Question about Pioneer DVR-231 DVD Recorder
Bought Pioneer DVR -231 one year ago, never used it to burn discs. I have now bought 3 different makes of dvd-r discs and it keeps kicking them out saying imcompatible disk, I know it takes dvd-r it says so right on the front. So what is the problem, it's going to get expensive buying discs til i find a make it likes it has to be something else.
Piotr Pachkaev
    Master:
  • Pioneer Master
  • 304 Answers
Hi!
Please cjeck the "Troubleshooting" part of the manual to a similar device!
https://manualsbrain.com/en/manuals/986740/?page=63
Posted on Oct 16, 2017
4 Related Answers
PERS_Malta
Patrick Joseph Gatt
  • 45 Answers
SOURCE: Pioneer dvr-225
no Sir there is nothing to do now because there will be no tracking of data apart from another pioneer dvr-225. Try inserting the disc in a similar dvd player! Please vote me solved Patrick
Posted on Jul 25, 2007
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: lost manual for Pioneer DVD DVR-231 recorder and Sound System
you can download user manual from retrevo by clicking it.
Posted on Jan 03, 2009
Anonymous
  • 70 Answers
SOURCE: Pionner DVR-540H-S no longer plays DVD's
little,
good day, true it's not advisable to use disc cleaner for it may also damage or scracth the optic lens inside.Possibly the optic lens of your player is either dirty caust by dust or faulty. but let's do hope it's only dust related and the only thing you can do now is to open and unscrew the upper cover of your player. Get a soft cotton buds, after dismantling the upper cover locate the optic drive lens and clean the lens by wipping it gently in circular direction. then try to play some DVD.
cheers,
mark
Posted on Feb 01, 2009
Anonymous
SOURCE: Disc tray won't stay closed.
I fixed this by jerking the tray gently. Someone jammed my tray and it skipped a few gear teeth. It seemed like the machine couldn't pull it in far enough to reach its preset position. So I let it close and when it was almost closed, I gently jerked it out to skip the gear teeth back into alignment. It is kind of tricky because the motor will just reverse instead of skipping teeth (you'll hear the plastic clicking when it skips). Perhaps unplug it and slowly push it in manually then **** it back out softly. Just be gentle. Good luck.
Posted on Aug 22, 2010
Dvr 231 won't load
Someone needs to open the unit to see if something that does not belong got inside and to see if mechanism is functioning or not. If it does not fully load the disc it will eject it on its own.
May 28, 2012 | Pioneer DVR-231 DVD Recorder
I have a Pioneer DVR-111 D or DBK or DSV on my PC tower and it's been there for about 2 years. I also had a Sony Burner on the same tower so I could burn from 1 DVD to another. The Sony went out so I...
first make sure that your dvd drive has power. to test just press the eject button. go to device manager, find dvd/cd-rom drives there and expand it. If the pioneer dvr is present and has an exclamation point then just reinstall the driver for that drive. if not there then check in the bios if its there, just got to system information in your bios. If not there then open your tower and unplug and replug the cable connecting your drive to te motherboard. then check again.
Sep 16, 2010 | Pioneer Computers & Internet
PIONEER BURNER BURNING BUT DISC EMPTY SAYS DISC FINISHED BURNING BUT WHEN TRYING TO PLAY SAYS DISC EMPTY AND I CANNOT USE IT AGAIN
What OS and disc brand and type are you using? Try a different brand; some disc manufacturers seem to make more "coasters" than others. If you are not using RW(rewritable) discs, make sure to cancel the autoplay "Format disc" option for blank discs in most Windows OS versions. I chose to turn off autoplay.
I hope this helps.
(Yes I made a few coasters. So far I've found that Verbatim DVD +R DL discs are good. CDs are fine with most brands. However, other reviewers say that the plant where the optical discs were made matters.)
Jul 09, 2010 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
PIONEER DVD-RW DVR-112D won't burn discs. G4, OS 10.4.11
So the driver is either 'malfunctioning' or it's broken...do you know what revision firmware the drive is using? Your disk authoring software may tell you this. The latest version is 1.22 which you can get by Googling PIONEER DVD-RW DVR-112D firmware. Or go to the Pioneer website. I do not know how to upgrade the firmware for the recorder in MAC Land, in PC Land the firmware update is a simple executable file.
If you are running this version you can try to reflash it. Have you tried another brand of DVD disc? Some discs are less compatible than others. Try another brand of DVD
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_3424/426554181POV_DVR-112D.pdf
Oct 13, 2009 | Pioneer DVR-112D Burner
DVDs burned with Pioneer DVR-110D do not play on the same burner
Are you burning the files with a DVD+R format. Use DVD-R. Not all players will recognize DVD+R. Also, check the region that the movies are made in and see if the player can be switched to that region. Also, are you trying to burn files larger than 700 MB. If you are, in creating an iso image or copy if you are downloading the file you have to match the checksum of the original file to the downloaded one.
Jul 25, 2009 | Pioneer DVR-109 DVD±RW Dual Layer...
I can't write DVD with my Pioneer DVR-107D DVD±RW
What brand of media are you using?
You are burning at 2x because that is the highest that this drive supports.
You would also want to instruct Nero to Verify by ticking the check box and either finalize disc or make it mulitsession, if your burner supports multisession DVDs
Regards,
Worldvet
Jun 13, 2008 | Pioneer DVR-107D DVD±RW Burner
Pioneer DVD-RW DVR-111d instruction manual
The manual likely is at the Pioneer website. But why do you need it? These drives stick in your computer pretty easily, and only function if you have a good DVD burning program installed. Did it come with an installation CD? Your burning program may be on that. If you run into trouble, just call Pioneer--they owe it to you.
Mar 23, 2008 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Dvd compatibility issues...
You should try updating the firmware in the burner. http://www.cdrinfo.com/Sections/Reviews/Specific.aspx?ArticleId=16989 http://wwwbsc.pioneer.co.jp/product-e/ibs/device_e/dev00001r_e.html scroll down a page or 2 and you will see the firmware upgrade for your model. Good Luck, Tim
Feb 07, 2007 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Pioneer dvr-225
Jan 23, 2007 | Pioneer DVR-225 DVD Recorder
Pioneer DVR-231 DVD Recorder Logo
75 people viewed this question
Top Pioneer Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
