Question about Whirlpool AWM8123 Front Load Washer
If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
Posted on Oct 28, 2017
SOURCE: Washing machine wont stop filling up
i had the same problem and found a piece of trash in my valve. The valves are controlled by a solenoid and are very sensitive.
Posted on Feb 29, 2008
SOURCE: whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Posted on Aug 17, 2008
SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Posted on Sep 11, 2008
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Posted on Feb 11, 2010
SOURCE: Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Posted on Mar 31, 2010
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Aug 11, 2009 | Whirlpool AWM9000 Front Load Washer
Dec 28, 2008 | Washing Machines
Dec 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Oct 05, 2008 | Whirlpool AWM6120 Front Load Washer
Jul 18, 2008 | Whirlpool AWM6100 Front Load Washer
Apr 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Feb 18, 2008 | Washing Machines
Jun 19, 2014 | Whirlpool AWM8123 Front Load Washer
Apr 07, 2014 | Whirlpool AWM8123 Front Load Washer
Sep 14, 2013 | Whirlpool AWM8123 Front Load Washer
246 people viewed this question
Dear Manweek:
Thank you for your review. We are sorry to hear of your Whirlpool® Washer concerns. Please email us at [email protected], with your name, phone number, street address, zip code, model & serial number, and date of purchase, and a brief description of the issue. We look forward to your reply.
Thank you.
Whirlpool® Social Media Relations
