KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
Posted on Nov 15, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our K5SS 300 watt mixer (30-40 years old) does not have a really slow speed anymore. We used it with the vegetable grinder accessory and when we were done it would not go slow on the slow speed. It went as fast as it did previously on the 3 or 4 speed. Is there an adjustment I can make to make it slow down to the normal 1 speed?
Bill Boyd
Level 3:
Top Expert:
  • KitchenAid Master 53,816 Answers
  • Posted on Nov 15, 2017
Bill Boyd
KitchenAid Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11950377
Points
172802
The speed setting is in the speed control unit which by your statement is now broken
no parts around for the lovely old reliable machine which is now close to junk
take it to an appliance repair shop as they may have spare from another machine or can repair the fault
4 Related Answers
defrankond
CJ C
  • 66 Answers
  • Posted on May 05, 2008
SOURCE: My Kitchenaid K5SS 300 watt standing mixer launches into the highest speed regardless of the speed ....
ok to answer both of your questions. the mixer needs a new speed selector switch. it sounds to me like the contacts are burnt out or worn out one. the motor is fine its just the motor isnt getting the right voltage from the switch. its either on or off or medium speed or no speed. either way you both have to replace the switches. you can get the parts and do it yourself at kitchenaid.com or your local appliance store should be able to get them for you to.
Anonymous
  • 16 Answers
  • Posted on Dec 30, 2008
I would recommend that you first check the Hall effect sensor which determines the speed.  I had this exact problem (but mine occurred with a 600 professional model) and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My blender worked as good as new! But I was curious to know if my original sensor was defective so I put it back in mixer and again made sure all of the connections were tight.  Guess what?  My original sensor also made my mixer work!  There was nothing wrong with my original Hall effect sensor except the connection between the control board and sensor was not adequate--unfortunately I didn't check the connections before I decided to buy another one. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations.
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall effect sensor looks like. 2.  You'll need a phillips head screwdriver to open up the mixer. 3.  Make sure that the connection between the control board and sensor is absolutely tight and snug. 4.  Also, make sure that the orientation of the sensor connection between the control board and sensor is correct. it's hard to know which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or facing down. If, after you've made the connections, the mixer still doesn't work.  Disconnect the sensor and reconnect it with the prongs facing the opposite direction and try it.  I actually found the right orientation through trial and error.  By going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work it were reconnected with correct orientation.   5.  This whole process probably takes less than 10-15 minutes to perform.
Anonymous
  • 257 Answers
  • Posted on Mar 06, 2011
SOURCE: which part do i need
Hello Jovana,
First thing you are going to have to do is take the planetary off and check the key and the gears in the planetary. The parts that you may need to replace are endless as we do not know what may be broke in the unit. More than likely it will be in the planetary of the unit if you get it off and do not find anything post back to this thread and I will get you started on the next step.
Thank you for choosing FixYa
Lance Hill
  • 1739 Answers
  • Posted on Apr 01, 2011
SOURCE: Where can I get like
Replacement parts for Wolfgang Puck Stand Mixers are available here:
http://www.wpcookware.com/categories.asp?cat=32
If you do not see the model number for your product or parts are not shown, suggest you contact their Customer service at 1-800-275-8273 to determine if the required replacement part is available for your model. Alternatively try making an inquiry via their webform:
http://www.wpcookware.com/contact.asp
325 k5ss mixer stir speed not working, but works in all other gears
First congrats on the great mixer that you have. next the pro 6 or professional 600 series mixers are of an entirely different design than the one that you have even though they are both bowl lift. Do you really need 6 quarts capacity? The pro series is a 575 watt mixer BTW, and it will have more power available to you IF you are doing bread or a lot of food grinding, if that is a requirement that you have then the 6 / 600 series is the better suited mixer but if all you are doing is general medium to light mixing duties then fix and keep the K5SS it a great machine,
1helpful
I could not regulate the speed as usual. Hubby removed the phase control board and a new one was purchased #9706595. It arrived and was installed and now the mixer won't even turn on. HELP please.
The K5SS is very similar to the 5-QT Artisan KSM150.
You need to adjust the mixer speeds. Obtain a copy of the K5SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Which part do i need to replace?It seems like I put too much flour.in the bowl.then the mixer started to work very slow.I havea kitchenaid mixer made by Hobart Corp. model k5ss max watts 300 hz 60...
Hello Jovana,
K5SSWW Stand mixer started slowing down while grinding shrimp
I'm not quite sure about this answer but it occurs to me that it could be the governor. It sits at the back end of the armature and as the speed control is slid to faster speeds the governor moves away from its rest position pressing against the control plate. If the governor's pivots were to be binding, even slightly, it would explain the symptoms you are describing. A service manual can be found at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Mixer works on high speed but not low. Brushes
Motor brushes are fairly cheap to buy. It sounds like the first place to start: http://kitchenaidmixerspares.co.uk/Home/tabid/36/ProductID/88/Default.aspx
Our mixer is slow and doesn't respond much to the speed selector.
Hi Sunny. Goto www.mendingshed.com They have a free Kitchenaid Service Manual that covers your K5SS mixer. Download it and get to work. I think that it contains electrical circuitry info. This manual is comprehensive and thorough and is absolutely necessary to succeed with your project.
If this solution has assisted you, please rate it. Good luck! ricardok45
Oil leaked from housing
my ultra power ksm90gr 300 watt mixer leaked oil when in the upright position overnight. whats that all about?
2helpful
4answers
My Kitchenaid K5SS 300 watt standing mixer launches into the highest speed regardless of the speed selection. It functions with a sliding knob and I can barely ease it from off to stir and it goes from no...
I had a similar problem where the mixer would also go to fast speed right away. On the back at the top was a screw that was loose. After tightening this screw I had 4 speeds but no stir speed. I unscrewed that screw and a bolt fell out. This bolt went to threads on the inside of the area covered by that back plate. I put that bolt back on and tightened it and the corresponding one on the other side and wala the mixer works perfectly at all speeds. Hope it helps. Make sure mixer is unplugged before attempting anything like this (wires are exposed when the back plate is removed - some kind of flexible circuit board).
KitchenAid K5SS mixer speeds up beyond set speed.
I have the same mixer and I believe your problem is the governor that is on the back of the motor. You can figure it out by downloading the repair manual here:http://store.mendingshed.com/kitaidparts.html The manual has all the info you need; including a troubleshooting section. The governor is availible from the the same site here:http://store.mendingshed.com/kagovernor.html What tipped me off on my K5SS was looking at the governor as it ran and I could see it moving back and forth; not steady like it should. Good luck!
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
