Cambridge Soundworks BassCube 12 Speaker Logo
Question about Cambridge Soundworks BassCube 12 Speaker
I have a Cambridge Soundworks Bass Cube 12s that has had off and on problems. Sometimes a popping noise. Last night at 2am it woke me up with a loud continuous low humming noise. Its Off/On/Auto swtich was on Auto and my Denon receiver and CD player were off. It was quite warm and smelled like hot electronics. I switched it to off and unplugged it. Afraid to turn it back on!
Posted by sbrownleger on
5 Related Answers
Anonymous
SOURCE: BassCube 12 Startup Problem
same here. happened after moving residences
Posted on Aug 29, 2008
Anonymous
SOURCE: Cambridge Soundworks Basscube 12S only makes pulsing buzz noise
I have solved my issue with the basscube 12s - I found a bad zener diode that regulated the voltage
to one of the amplifiers power supplies. It was caused by a cold solder joint during manufacturing of the
circuit board. The amp is located behind the heatsink on the back of the cabinet. This symptom could
be caused by any of the components in the power supply circuits. Hope this helps!
Posted on Feb 26, 2009
Anonymous
  • 7 Answers
Hey! So i fixed my problem! This is for the BassCube 10
Like i said before i saw that the circut board was burnt near the diodes ZD3 & ZD4, and the resistor R63. Thanks to Deadly1 and BillRad62, i figured it out. The R63 is a 1200 resistor, and the diodes are 15v zeners. I went with 3x 5.1v zeners to replace ZD3, unfortunately Rip-Off-Shack (Radioshack) didnt have 3 packs of these so for the ZD4 i put a 12v and 5.1v. Which exceeds 15, but seems to work without a problem. Hope it helps!
Posted on May 26, 2009
Anonymous
  • 113 Answers
SOURCE: Bass Cube 12 makes loud buzzing noise when turned on !
Hi Ok thanks. I cannot be 100 % sure about this without seeing it but it sounds alot like there is a power supply issue, either bridge rec or caps. Caps are very often very obvious. If you get into it and have a look at what is normally the 2 or 4 biggest capacitors at the start/power supply of the board and see if they are ok visibily. If they are bulged, (often they actually explode and leave paper residue) then those are what need to be replaced. Have a look and see.
If its the bridge rec, it could be 4 diodes, fairly large next to each other or a square component with 4 legs out. Need a meter to test, but i would start at caps first
All the best
Posted on Aug 05, 2009
mc1bean
Mike Cairns
  • 3053 Answers
SOURCE: How can I replace a
Its pretty simple actually.
If you already have the same size new tweeter. You take off of course the large felt cover so speakers are exposed on front. Just like your picture is in this post. Then you should see some screws, most likely it is going to be Phillips. Then unscrew all the screws, the whole front should slide out with of course speakers still attached, don't pull out to fast or far, to make sure the internal wires are long enough to take whole front out and set aside speaker box, the on back of speaker should be two wires going to it, maybe three if is tapped in conjunction with a ground. Anyway on back of speaker unplug the wire from speaker and then, take out screws which is normally on back of speaker, pull speaker out, put new one in and repeat steps in reverse order. Hope this helps. Mike
Posted on Jul 07, 2011
Cambridge Soundworks model 765i
Yes, it does exist. $150 and it's yours. Here is a review as well.
Cambridge SoundWorks i765 review - CNET.com
www.cnet.com > reviews > cambridge-soundworks-i76...
Feb 15, 2008 - The i765 is the latest and greatest entry from Cambridge's well-regarded line of stereo clock tabletop radios. The new model also boasts a slot- ... Rating: 3.5 · ‎Review by Steve Guttenberg
Cambridge Soundworks 765i Music System for sale online ...
www.ebay.com > ... > Home Audio
Cambridge SoundWorks 765i CD Radio/iPod/Clock. About this item ... Playable Media Format. CD. Model. 765i. Brand. Cambridge SoundWorks. Features. Hi-Fi. US$150.00 · ‎In stock
1helpful
I need circuit diagram for Cambridge Soundwork Slim 500 model. Where I can find it?
    Cambridge Soundworks circuit diagram cambridge audio a1 ...
    www.fixya.com > ... > Tags > circuit diagram cambridge audio a1 mk3
    Ask your Cambridge Soundworks circuit diagram cambridge audio a1 mk3 questions. Get free help, advice & support from top Cambridge Soundworks experts. images for circuit diagram for Cambridge Soundwork
Replacement part or schematic for Cambridge Soundworks computer speakers
I'm in the same predicament! I found this - it seems close, though the pins seem to be spaced closer together, but it looks like they might be bent to fit the wider PC board spacing. The rotating shaft also seems smaller - the original is larger than 1/4".
What do you think?
Woofer has popping noise
I have the same problem with my Cambridge Soundworks CSW250. Also one of the speakers doesn't work all the time. I'm sure it's a loose connection on the circuit board. When I tap the subwoofer near the connections, the popping noise changes (gets worse, better, other speaker works,etc.).I tried taking the subwoofer apart, but the area near the connections is sealed with glue, so I cannot access it. I hate it because when it works,it sounds so good. Anyone know how to get just the circuit board and back panel?
6helpful
3answers
All the best
2answers
Fluctuation in sound output on Cambridge Soundworks 5.1 speakers
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
Open Questions:
See all Cambridge Soundworks BassCube 12 Speaker Questions
Top Cambridge Soundworks Audio Players & Recorders Experts
Marvin
Marvin
David Shaub
shadow
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
