SOURCE: i need to reset my dishwasher but don't know how!!
bdw13 showing e4 & trying to empty when no water in it
SOURCE: Baumatic BDW13 14 dishwasher SHowing E3 Fault
I had the same problem and changed the two thermostats on the base and got it working. You can get them from partmasters.co.uk (thermostat protector) cost 17.99. They just screw in and are dead easy to fit
SOURCE: error code on my bdw13 dishwasher
Turn off the water and electric!
Its really easy to change the heater element, once you have taken out the dishwasher!, remove the bottom panel and remove the wiring to the element, slacken off the nut under the electrical contacts voila!, also it may be a faulty thermostat that you cannot reset and has to be replaced, I would do this at the same time, as again its easy with the bottom off.
SOURCE: getting error code e3 on display- not reaching
the problem is the heat element, it is to replaes..dont now the prise..i am from denmark...
Testimonial: "thanks mate its good to know the problem"
SOURCE: I Need a user's manual for a Baumatic Dishwasher
You can get the manual here on link below.
http://www.tlc-direct.co.uk/Technical/DataSheets/Baumatic_Manuals/BMBDW13.pdf
Good Luck
Testimonial: "BRILLIANT !! THANK YOU VERY MUCH."
