Using the Fn+F4 key? that?
this lap top, not really a dual monitor system
the rear VGA jack is used for presentations, like a projection system.
what are you doing with this laptop, what is the reason for 2?
my key (above) GOES
Internal
external
both
and
AUTO. so turn off AUTO
which I know what application this is for, the end goal or job.
computers have vast usage, (my bag, for 36 years just PC)
even 10 monitors on one PC ive done.
and more.
all kinds of problems, doing WHAT?
tell how the monitors are connected, in detail even there model numbers.
are you using custom or special connections to the monitors?
this pc has just one VGA rear port jack
and TV-Out (S-video)
came new with VISTA OS.
SOURCE: Data Shows up only on External Monitor, not on Laptop Screen
Since the laptop works on the external monitor, then it would be safe to assume that it is only the L:CD display part that is the issue. Often LCD display (of laptops) are working but only that you can see the actual display. One way to verify is to shine a flashlight at an
oblique angle to the screen, semblance or part of the desktop could be
seen. If the
desktop could be seen (albeit very very dark background) then it could
either be the CCF Lamps (cold cathode florescent) or the inverter that
powers the lamps.
Often, the defective component would be the inverter. It is
relatively easy to replace the inverted. It is sometimes more difficult
and challenging cracking open the casing of the display panel of the laptop than replacing
the inverter. Additionally, inverters are readily available online. It
is also not surprising that inverters for other brands/models would
also be used in your Toshiba.
This would be a good place to start for inverter boards. This is a nice tutorial if you are considering a DIY.
In some worst case scenario, it could be the video interface or even a loose/open flat cable from the laptop's main body towards the LCD display panel.
Hope
this be of initial help/idea. Pls post back
how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: hp dv9000 monitor issues
The Black Screen of death...
you gotta replace your mobo(200$), or reflow the gpu(20$)
SOURCE: Using notebook display and external
First make sure Primary display driver installed and working properly.Make sure it's screen resolution is 1024*768. If still same then uninstall primary display adapter driver then reinstall. then it will work fine. Let me know if you need further assistance. Thanks for using FixYa.
