I went to download pictures to picture project today and received this error message=Pic.projuect has encountered a problem and has to close. I tried several times and the same message. I thought maybe by uninstalling and re-installing would solve the problem but it did not.
Help!
SOURCE: Nikon 4300 CF Card Erro
The Nikon Coolpix 4300 only supports the FAT16 filesystem, so it can only support a 2GB partition. To support 4GB you need a FAT32 filesystem.
Put the card in a CF writer and attached to a PC or Mac. Partition 2x2GB partitions, then format them as FAT16. Now put it into the Coolpix 4300 and it should work.
SOURCE: Pictures messed up between camera and computer
It sounds like jpeg file corruption. What do the pictures look like on the camera's screen?
If they look OK, try using a card reader to transfer the pictures and not the camera. do they transfer OK now? If not then the card may have a problem OR there is a problem with the USB on the computer that is causing it.
If they look wrong on the camera then it's possibly the card at fault.
What I would do is download what pictures you can and then give up on the others and reformat the card in the camera. That will clear the card as if it as brand new. Take some more pictures and see if you can transfer them successfully.
I've had a card fail (so far only 1) and it's really annoying, reformatting didn't help either, it was still faulty!
There is always the possibility that the camera is at fault! I hope not.
Try shooting some pictures in RAW format instead of jpeg and see what happens then.
SOURCE: Nikon CoolPix problem downloading pictures to computer
go to picture project and click on transfer select ure camera then select the photos u want
SOURCE: Help! I'm trying to transfer my pictures from my
Blame Microsoft updates. Use a card reader to download your pics to a folder you create on your desktop.
SOURCE: When I turn the camera on , it says "lens error"
If brand new, take it back immediately to the store for exchange. It's defective.
