Sony Cyber-Shot DSC-T3 Digital Camera Logo
Question about Sony Cyber-Shot DSC-T3 Digital Camera
Won't charge or power up - new battery?
My camera won't charge or power up. I bought a new charging/sync USB cable for it, but the charge light is not lighting up. The camera doesn't power up even when plugged in. I hit the reset button, and the LED next to it blinks red once. I'm not quite sure what that means.
Do I need a new battery, or does it seem like something worse and not worth the battery purchase?
Thanks
Dan
Posted by Equilibrium7 on
  • anil_sahoo Dec 19, 2008
    My camera won't charge or power up. The charge light is not lighting up. The camera doesn't power up even when plugged in. I hit the reset button, and the LED next to it blinks red once. I'm not quite sure what that means.
5 Related Answers
Anonymous
  • 326 Answers
SOURCE: Camera does not turn on
Hello, reset in this case is not a solution. Maybe your lens is stuck. For further info please contact me at LIVE session. Best regards, Arpi
Posted on Jun 24, 2007
Anonymous
  • 480 Answers
SOURCE: camera not sataying charged
Hey stacytwo,
I would try cleaning the battery contacts first with a cotton swab, and if this doesn't work I would try initializing the camera back to its factory default settings as described on page 53 of your camera manual. If these options don't work I would try purchasing a new battery. I have included a link to a PDF download of your camera manual in case you need it. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jul 29, 2008
Anonymous
  • 3 Answers
SOURCE: Seems like batteries don't work, but . . .
I think the problem was either dirty battery contacts or a broken connection somewhere with the battery terminals. I'd cleaned the contacts a number of times with a pencil eraser before, but nothing worked. This time, I just did it again and paid careful attention that both contacts on the battery door were protruding properly--could be that one of the contacts got pushed back such that it wasn't making proper battery contact. All I know is that it's working now, perfectly, after sitting for a couple of years on the shelf. I really like this camera.
Posted on Feb 04, 2009
Anonymous
  • 44 Answers
SOURCE: After charging the Battery the power button flash blinks
i think the red light means low power for battery... maybe just maybe your battery didnt really charge.. im not saying that its the charger, but try to buy a new rechargeable batteries, use it then charge it and compare it with the other one... i think thats the problem with batteries if we stop using it for a long time... hope ull be able to resolve it
Posted on Sep 13, 2009
Terry Herrera
  • 109 Answers
SOURCE: my T1 is experiencing power problems. I have
DSC T1 li-ion batteries goes bad in a period of 3 to 5 years of continusly use (daily). i will recommend to buy a spear charger that charges the batteries without using the camera.
Posted on Oct 09, 2009
Charge light solid red
If you put a cool battery in a camera and the camera says it is too hot. you have a critical problem with either the battery or camera.
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
Switronix Tl-50 won't turn on
I too have had a problem with mine no longer charging. I talked to the manufacture. Since the cord light is on however my torchlights charging light is not on they said could be the batt or could be a bad wire in the charger. I've been debating whether to send it in for fix or buy a new batt to try first. For yours I would send in for repair. Unfortunately these lights only come with a 1 yr manufacturing warranty so if you've had it over a yr you will end up paying 60-130 was the price range I was quoted depending on the problem.
2answers
Iphone won't charge if on
Hello My Dear::::::\
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
How do i get my laptop to power on? Have new power cord but still will not power up
There is a possibility that if the battery is shorting out it won't hold the charge or let it power up.
My kodak easyshare MD41 has had charging issues since I bought it.. The USB cable that came with the camera won't fit right into the camera's port. I really had to push to get it in. Well, now it...
You will just need to buy a new cable.
Something like this:
http://www.amazon.com/Kodak-EasyShare-MD41-USB-Cable/dp/B003HMVF70
Hope this helps! Good luck!
2helpful
Hi! My Nikon S570 model won't turn on. I haven't dropped it or anything and I charged the battery and it was complete. I've had this camera since February 2010. What should I do?? -Monica
i have a nikon s570 that is about 18 months old. (not under warantee anymore) it won't turn on, so we bought a brand new battery, charged it and it still won't turn on. Nothing. no motor noise, no lights, nothing. any ideas? nikon wants us to send it to them for evaluation and fixing....any thoughts?
Battery won,t charge
the price of KLIC7001 $29.00 try to purchase the battery at wallmart target or at kodak.com/go/shop.,
how do you charged your camera USB cable or AC adaptor? if USB cable make sure that the Cable is working fined and the USB port of a computer is not defective., If the AC adaptor., try to clean the 3 metal contacts of your KLIC7001 using clean dry cloth, then charge it again. if its failed., try to test first the camera itself using different KLIC7001 if its not charging it means the problem is on the camera not the battery
4helpful
2answers
Can i charge the camera other than through the usb cable ??
Hi!
USB charging is not possible. You need to have the battery charger to be able to fully charge the battery. This should come along with the camera kit.
USB charging is possible if you will buy this: http://fujifilm.co.uk/consumer/digital/digital-accessories/usb-chargers-travel-adaptors-153171/world-adaptor-plus-usb-charger
"For charging by USB, simply change the head and plug in your iPod, mobile phone, PDA or any other 5V USB powered device to keep it fully charged wherever you are."
Top Sony Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Sony Camera Expert? Answer questions, earn points and help others
