Question about Breville JK73 Cordless Electric Kettle
Hi wondering if you can help me please. My Breville Illuminator kettle with the blue light has stopped boiling the water but the light still comes on. Will the light come on if the element has gone? Seems ironic as the only posts I can find are about the blue light. Thank you in advance Sharon
Posted by sharonmevans on
Vanessa Lum
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Indicator light is on a separate circuit than the coils that heat the kettle and water.It is unlikely you can get a replacement element to fix your issue.
Posted on Feb 06, 2018
5 Related Answers
bengsoon Neo
  • 63 Answers
SOURCE: Problems with Breville SK500XL Stainless Steel Cordless Electric Kettle
you need to change out the heating element.For electric kettle, alway remember to fill up water before you turn on the kettle.never poure water while the element was hot.hope it help.
Posted on Aug 13, 2007
Anonymous
  • 274 Answers
SOURCE: new kettle breville
There's several home remedies you can try: Try 50% "White Vinegar", 50% Hot Water or 2 Denture tablets in warm water over night or Baking soda in warm water. These remove the alkaline, minerals, and nitrates that build up on the surface. There is even a commercial product you can use to clean it. I can't recall the name but look in any supermarket, you should be able to locate it.
Posted on Sep 11, 2007
Anonymous
SOURCE: illuminator kettle
me too mine has stopped working any one know how to change the bulb? looks like a common fault
Posted on Jan 11, 2008
Anonymous
SOURCE: filter for breville kettle jk155
Contact Breville on 0161 652 1211 and they will mail out one
Posted on Feb 26, 2009
Anonymous
  • 4 Answers
SOURCE: Automatic switch off not working when water reached boiling.
There is no do it yourself fix for this problem. However, placing a folded cloth on top of the kettle (covering the spout) will cause it to switch off quicker, as it increases the pressure inside the kettle.
Posted on May 04, 2009
Breville hot cup
Breville Hot Cup spitting:
Hi Louise.
My HAZ upright kettle did the same thing recently.
Sounds like your element-tube has a rust-hole, which allowed water to enter the normally dry and cozy filament area. The water that seeps inside hits the red-hot filament, vaporises to steam which violently expands out of the pinhole.
Remove element, check for corrosion, renew.
Hope this helps. Clive.
Oct 09, 2017 | Breville Kitchen Appliances - Others
How do you clean a Breville JK73 kettle. I have lost the instructios.
Put a cup of vinegar and a cup of water into the kettle and boil. Clean with a brush, rinse, boil once with clean water.
Aug 05, 2010 | Breville JK73 Cordless Electric Kettle
How do I clean
Fill kettle until 3/4 full with 1 part vinegar and 2 parts water. Boil and allow to stand overnight.
Empty solution from kettle. Fill the kettle with clean water, bring to boil and discard water. Repeat and the kettle will be ready for use.
Or you can use a proprietary kettle descaler, which is available at most hardware stores.
May 16, 2009 | Breville SK550XL Electric Kettle
Siemens porsche kettle on/off switch problem
Hi
Make sure that the lid is securely on. Otherwise its the replacement of the auto bi metalic strip which turns the kettle off
Feb 14, 2009 | Breville SK500-XL Stainless Steel Cordless...
Filter for breville kettle jk155
Feb 09, 2009 | Breville Kitchen Appliances - Others
Light switch on Breville SK500-XL Kettle
e mail [email protected]
Send them model number
PDC code (on bottom of kettle)
your name and address
where and when device was purchased
They can send you a part or send you a FEDEX label for a warranty repair.
This is a very common problem
Jul 24, 2008 | Breville SK500-XL Stainless Steel Cordless...
Illuminator kettle
Sep 06, 2006 | Breville SK85XL Nova Cordless Electric...
Breville JK73 Cordless Electric Kettle Logo
101 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Marvin
Marvin
Anthony Ward
Anthony Ward
Irene Tulloch
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
