Your blend door actuator gear is slipping. remove actuator and check blend door for free movement. If jammed, you may have to open the system to unjam. If door is free to moe, replace actuator. See procedure below to access blend door. Not sure you need a lift, as long as you can get the 2 nuts off under the truck.
Fig. Blend door actuator - auxiliary
(1) Auxiliary line floor pan bracket nut (2 req'd)
Removal & Installation
(2) Auxiliary housing bolt
(3) Auxiliary housing bolt
(4) Auxiliary housing nut
(5) Auxiliary harness electrical connector
(6) Blend door actuator electrical connector
(7) Screw (3 req'd)
(8) Blend door actuator
To install:
Auxiliary line floor pan bracket nut (2 req'd), 71 inch lbs. (8 Nm)
Auxiliary housing bolts, 62 inch lbs (7 Nm)
Auxiliary housing nut, 62 inch lbs (7 Nm)
To troubleshoot this types of problem,click the link below
:----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the
issue.
Engine Overheats and heater
blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers
side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
This will help.Thanks.
