Question about Proscan 32LA30Q Television
I GOT A 32LB30QC, TO REPLACE AN OLD (6 YEARS) JVC AND THE PICTURE, COLOR AND DEFINITION OF THE JVC UNIT IS A 100% SUPERIOR. I TRY TO ADJUSTE THE PROSCAN IN ORDER TO GET A BETTER PICTURE WITH NO RESULS. PLEASE TELL ME WHAT TO DO MY SELF, I JUST DO NOT HAVE THE MONEY TO TAKE IT ANY WHERE. THANKS.
Posted by stgopas on
2 Related Answers
EXPERT-TECH
Sam Farrell
  • 31 Answers
SOURCE: My 3 year old Proscan 42" LCD TV picture suddenly
On the far left and right inside the back on panel are inverter boards. Replace or look for capacitors buldged, swollen, or cracked on their tops. Replace defective caps with original value and make sure replacements are 105 degree for longevity. Common problem, let me know if this helped.
Sam Farrell
Posted on Feb 17, 2011
TODDAS
Todd Hill
  • 433 Answers
SOURCE: Proscan 32LB30QD Color Problem
Try resetting it to factory settings and see what the color looks like.
Posted on Nov 21, 2011
Tv is about 6 years old hd-ila 56g657 have replaced lamp 3 times over that time but the picture started to get darker and darker.the last time i replaced the lamp it did very little good and the ptcture...
you cleaned the reflector glass, then tried to make the manual adjustment of the color to have good convergence. you can do the adjustment in the menu set up. if can not get with adjustment, their might be a problem in the convergence circuit board.a bad convergence ic or resistor.
Nov 18, 2012 | JVC HD-56FB97 HDTV
Bought this from a friend two weeks ago and she replace the picture tube last year. tonight the picture has double picture and the ghost picture is blue. please help. jvc manu january 2003 model number AV...
This is what is called a convergence problem. It is a fairly common problem. This is where one or more of the colors do not strike the correct positions on the screen. There is a special circuit built into the television that controls this very function. If your blue is very close to the other colors it may just need to be adjusted. If the blue is very far away you probably need to replace convergence IC's (or transistors depending on the circuit) and do an alignment on the unit. Check the owner's manual on how to adjust convergence, but only if the blue is SLIGHTLY off from the rest of the colors. If you adjust it and it turns out parts need to be replaced, you have just shot yourself in the foot and the final adjustment will take more time and/or end up costing you more because of additional time required because what you have done must be undone in order to align everything. I hope this helps.
Apr 06, 2011 | JVC Televison & Video
Have a 27 " JVC
Hi ,
welcome to Fixya, it sounds like you may have a weak CRT (picture tube)
If the TV is over 6 years old that may be the case.
There are RED, Blue and Green color balance adjustments that you can try .
referencing the exact model one could see how it adjusts.
hope this helps
Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Mar 11, 2011 | Televison & Video
Poor quality picture. specifically the red is brown and can't be adjusted. the tv is about 3 years old.
If the picture is replace the lamp. Lamp only affects brightness if the color is wacked replace the light engine.
Mar 26, 2010 | JVC HD-56FN97 56" Television
Current value of a jvc 32 inch color tv 8 years old
The street value would be 100-150 dollars. If TV is a cheap model or abused or very used, you should pay less.
Consider a Sony or a Toshiba in tube style since all are cheap now.
Sep 27, 2009 | JVC AV-27D302 27" TV
Dark picture on 62" lcd
how old is the lamp , if is about a year old need a newone
May 12, 2009 | JVC HD-61Z575 61" Rear Projection...
TCL TV picture too dark
try turning the light sensor off
Oct 20, 2008 | JVC AV32F476 32" TV
PANASONIC 36" TAU --- NEED HELP
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
I hope someone else can help you.
Good Luck!
Apr 01, 2017 | Panasonic CT-36D32 36" TV
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
Dark picture
How old is the TV? More than 6-7 yrs? Then it's time to do a trade in. But if you are very attached to it, get a Technician to recondition the Picture Tube. This may give it life for another couple of years. You could also ask a technician to check the DC filter Capacitor for the HT line to the Video Drive circuits. Over time this capacitor dries out and also causes a darkening of the picture. It is normaslly a 100 mfd 160V capacitor.
Sep 08, 2006 | JVC AV-27D303 27" TV
Proscan 32LA30Q Television Logo
102 people viewed this question
Top Proscan Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
