Question about Polaroid TLA-01511C 15 in. LCD Television
Polaroid 15.4" TLA-01511C Broke?
My TV stopped working recently. It froze and when I went and unplugged it to reset it the picture stopped working. When I plug it in I can hear the speakers kick on...But there is no picture and the power light is no lit. Could this be a picture issue or maybe something to do with the motherboard?
-Kyle
Tom Chichester
    Top Expert:
  • Polaroid Master
  • 55,973 Answers
Could be power supply failure
Posted on Nov 04, 2017
5 Related Answers
Anonymous
SOURCE: DirecTV Remote Control of Polaroid TLA-01511C
These worked for me
Polaroid 10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328, 11341, 11498, 11523, 11991, 11992
Posted on Dec 10, 2007
freetek
Steve Allison
  • 5569 Answers
SOURCE: polaroid TLA-01511C
It sounds very much as if you have the wrong source selected.
Go to the main setup menu and look through the functions there.
You should find a choice of inputs such as 'Cable' 'Antenna' 'Composite' perhaps also 'HDMI' and 'Component.'
If you are set to the wrong input, the TV will give that message.
You didn't mention where your signal originates (cable, satellite receiver, etc.) so I cannot tell you which setting you need to select.
Posted on Jun 17, 2008
Anonymous
  • 19 Answers
SOURCE: manual for TLA-01511C
olsonde,
Here is your product info. Please let me know if I can help you in any other way! If not, I would appreciate you rating this as "FixYa".
http://www.polaroid.com/CES/SupportProductDetail.jsp?prod_code=PT261&folder_id=0
-DRebel
Posted on Apr 03, 2009
Anonymous
SOURCE: I have 3 Polaroid TLA-01511C 15 in. LCD Televisions
I replaced three capacitors on my power supply board and the unit started working again, There was two 680uf 10v caps and one 1500uf 10v cap bad.
Posted on Nov 29, 2009
Anonymous
SOURCE: I have a Polaroid TLA-01511C 15 in. LCD Television
Radio Shack is your best bet. I replaced two 680uf 10v caps and one 1500uf 10v cap. It now works just like brand new. The caps I replaced had higher voltage values hopefully this will help prolong the life of them.
My polaroid tla-01511c lcd TV has a problem. When I turn it on, it works fine for about 15 seconds, then the screen goes blank but the audio stays on. When I turn it on again, the screen only stays on...
Buy cymbalta. Customer service worldwide, discount system, round-the-clock support from our staff. Regular online pharmacy at affordable prices. We are fully dedicated to your privacy and security. No delays in delivery. Any drugs without prescription.
*** Click Here To Buy Cymbalta Online ***
buy cymbalta
buy cymbalta cheap
buy cymbalta 60 mg
buy cymbalta medication
buy cymbalta generic
Oct 09, 2010 | Polaroid TLA-01511C 15 in. LCD Television
My Polaroid TLA-01511C has sound but no picture...what do I do
Replaced the LCD inverter backlight board is dead.After U replaced this LCD inverter board.U will get ur picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board.It a long board shape.
Feb 21, 2010 | Polaroid TLA-01511C 15 in. LCD Television
I have a Polaroid TLA-01511C 15 in. LCD Television that has no picture but does have sound. Solution #1 in this page says "a bad cap in the power board, the can like device will have a puffed up top from...
Nov 27, 2009 | Polaroid TLA-01511C 15 in. LCD Television
I have 3 Polaroid TLA-01511C 15 in. LCD Televisions that have no picture but does have sound. Is this a common problem with this model?
Nov 20, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Problems with Polaroid TLA-01511C 15 in. LCD Television
It needs a video board replaced most likely. You can find by searching on google for your model. Might cost more than set is worth. Think about new model as they are really cheap in that small size.
Feb 04, 2018 | Polaroid TLA-01511C 15 in. LCD Television
Screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
May 05, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Manual for TLA-01511C
olsonde,
-DRebel
Apr 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Polaroid TLA-04641C no sound
You should go into the menu SOUND section of your tv. Look for the TV Speaker choice option.
This will have to be turned on to get sound from the tv.
Feb 23, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Will Not Find A Signal Polaroid HD 15" TV - Model TLA-01511C
same (tla-01911c) issue when trying to watch over the air brodcast try rescanning the channels that normally works for me
i got direct tv basic set on my S-video input so i only need over the air when the sat is down (i.e: storms, wind, snow, ...)
May 15, 2008 | Polaroid TLA-01911C TV
Polaroid TLA-01511C 15 in. LCD Television Logo
110 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
