Try this, Loosen the two bolts that holds the front master cylinder onto the handlebars. Slide the master cylinder as close to the right handlebar switch housing as possible. If that doesn't extinguish the light, your front brake light switch is probably broken.
To change the switch, you'll have to open the right handlebar switch housing by removeing the two bolts that holds it together, take the throttle and idle cables loose and get the lower housing loose from the handlebar. The switch is held into the inner face of the housing by a single screw. Take the switch loose and desolder the two wires leading to it. Replace the old switch with a new one and solder the original wires to the new switch. Reassemble the throttle assembly and the switch housing. Check the throttle for proper operation. Make sure the throttle "snaps" shut when you release the throttle grip. Improper assembly or adjustment of the throttle cables can cause the loss of control of the motorcycle resulting in serious injury or death.
Good Luck
Steve
