There are two rods inside the tailgate.One for the driver's side latch and the other for the passenger's side latch. They are connected to the handle with "swing away" plastic connectors. If you lift the handle and look under it you should see the driver's side rod still hooked to your handle, and nothing on the passenger's side. If both rods are still connected to the handle, the repair is going to be much harder. Let's hope only one is connected. Unbolt the handle and pull it out far enough to disconnect the rod/rods, ( you might want to tie a string to it so it doesn't fall out of reach before you disconnect it ). Now grab both rods with needle nose pliers and pull them toward the
center, if the passenger's side is still connected to the latch, this
should open your tailgate. If the passengers side is not connected, try
getting a long stiff wire with a hook on the end to activate the latch,
it may take several tries, but just be patient and careful and
persistent. If this doesn't work, hopefully someone else has a solution,about all I have left is cutting the
strike bolt on the passenger's side, ( going to be very hard to do ),
or breaking the tail light lens and trying to remove the strike bolt, (
last resort before destroying the tailgate ). I'm posting a picture of
a typical swing away connector to help, they are color coded and this
isn't the proper color, but it will give you an idea of what it looks
like and how it attaches the rod to the handle.
