Just installed, and found that it sometimes locks up during
normal operation when accessing random
functions using the main panel. It locked up two times
in the first half hour of use. Pushing the inset RESET button
(with a pen) seemed to fix the problem. When it's in the
locked up state none of the face buttons work, including
the OFF button. Strangely, accessing the unit via the remote
does work OK while in the locked up state.
Unless they're using MS Windows I have to assume its
a defective unit. Is this a common problem?
P.S. I think/hope the CDX-GT32W is exactly the same as
the CDX-GT320, where the 32W specifically sold at Walmart.
SOURCE: No sound from cd or aux on CDX-GT32W
Just connect together the solid blue wire on the main harness to the radio with the blue/striped wire. The blue wire is for the power antenna and the blue striped is for the remote amp. but if not connected together only the fm/am has outputs to the line output RCA jacks. I learned this through Sony's tech line and it works perfectly now.
SOURCE: i need a wiring diagram
Hi I need a wiring diagram .to now what colours are what I have a Sony cdx-gt24
