Question about DISH Network IR Remote Control
The lights on my dvr remote do not come on when I push them in the dark. How can I fix this?
Posted by amyj_hendric on
Anonymous
    Scholar:
    New Friend:
  • 24 Answers
Have you checked to ensure there are fresh batteries in your remote control? Do all the remote functions work correctly? Has this issue recently become a problem? Does it appear that the only problem with the remote is that the buttons do not light up when you are pressing them or is there other remote control issues? If you replace the batteries or have already replaced the batteries and this continues to be a problem, then the remote is most likely defective and we may need to send you a replacement remote. If this problem hasn't been resolved yet and you need assistance getting a new remote ordered for you, please feel free to e-mail me @ [email protected], and I will be more then happy to help you in getting a new remote sent out to you. I hope this helps!
-Kirstie DISH Network
Posted on Jan 30, 2011
How do I reset the universal remote after a long power cut
Find the code and try to reprogram it or have the remote tested to see if it is sending a signal or not---most shops can and will check it for free--a digital camera in a dark room will react (most of them) when remote is pointed at it on the camera display with a flash of light.
Oct 30, 2012 | Arris dct3416/2305 dual tuner dvr / hdtv...
When i reboot my Zmodo dvr I Can't get menu to come up or mouse to work HDD light keeps flashing,blinking hdd light,HDD indicator light
I had the same problem. Did their online tech support and Patty told me to hold down the "rewind" button on the DVR for 20 secs. You should now be able to right click your mouse to access the on screen menu. You will now want to go under system, and a/v setup and change the device to VGA instead of Vout. Now you can reboot and not have to go thru holding down the buttons anymore. Worked for me.
Oct 02, 2012 | ECHO1USA Zmodo 4 Ch Complete Dvr Kit -...
I have a toshiba ct 90159 - I need the code for a coby dvr model dvd 627
u should be able to
turn the dvr on
press and hold the setup until the light stays on (remote)
hit the dvr botton on the remote the light should blind once
hold the remote towards the dvr keep hitting the on and off button on the remote until the dvr turns off can take up to 300 times once the dvr turns off press the select button and that should fixya up
Mar 31, 2012 | Toshiba CT-90159 Remote Control
My dvr freezes. i have picture and sound but unable to change the channel or anything dealing with the dvr. i have to manually push the system info button on the box then select done with the remote. ...
Believe it or not, this could be a simple battery problem in your remote. When my battery is low in my remote, some buttons will work and some not. I'd try replacing the batteries in the remote first. If that doesn't work, I would guess that you need a new remote. Sounds like your DVR works fine manually, so chances are that's not the problem.
Hope this helps.
May 14, 2011 | DISH Network DVR-625 DTV Receiver /...
I received the vivitar dvr 850hd with the 2.4" screen. i can't get the flash or strobe light to work to take pictures or movies when it is dark. is there something special that i need to do to get it...
When in the 'Camera' setting, push the left arrow on the camera to 'Auto' or 'On'. the flash should flash if it is dark enough. also, I don't think you can use the flash when making movies.
Jan 01, 2011 | Vivitar Cameras
I pushed some button on my remote and now I can't get my tv to work. Any suggestions?
Guest,
If you are not getting a picture on your TV, check to see which light on the remote lights up when you press the "Select" button. If anything button other than the "Sat" button lights up, the remote is not in satellite mode. Pressing and releasing the "Sat" button on the remote will put the remote back in satellite mode. I hope this helps.
Ray Calo
DISH Network
May 20, 2010 | DISH Network 721 DVR Remote Control
How do we fix the remote?
Have you tried to insert the remote codes on there again? Some remotes might reset if you take out the batteries but higher end ones do not since they have an internal back up system.
Try the codes and if that doesnt work then let us know.
Otherwise make sure the press the correct "source" you intend to opperate with it. such as the DVD player on component, or DVR on HDMI, etc... Some times if the wrong source is pushed it wont work. But normally pressing it will fix the problem.
Keep us posted!
Jun 15, 2008 | RCA RCR311B Remote Control
Program Comcast remote to operate Samsung 46"LCD
The answer depends whether its a Comcast DVR Remote or a regular one. The DVR codes are 4 digit -- the others are 5 digit. I got 0060 to work for my DVR remote.
May 18, 2008 | Samsung TV Remote Control
I have an AKAI PDP4273M monitor and DirecTV R10 DVR( TIVO). I canot control on off and volume of the TV with my TIVO remote. The codes listed in the DVR do not work. I have the same problem with a...
best bet for this is logitech unv harmony remote more way more compatbilty with all units u have even the lights it dims and glows in dark so u can see on sale now at best buy
Jan 18, 2008 | Televison & Video
DISH Network IR Remote Control Logo
Top DISH Network Televison & Video Experts
matt martin
matt martin
Sheldon Dedek
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
