Hello there:
A lot of the times the problem lies with in the Cycling thermostat
that is going out Although
this isn't a common problem, one of the thermostats that controls the
temperature in your dryer may break and cause the dryer to heat poorly.and can make the dryer stop working after it is working for a given amount of time
If so, you need to replace it.
Next is the The thermostat is usually a small, round,
black device mounted to an oblong steel plate. The plate is mounted to
the internal ductwork with two screws.
It overheats and shuts down due to a bad thermostate
Usually
when an electric dryer overheats it's because of a defective cycling
thermostat or a clogged vent system. Clean any lint from the internal
and external ductwork, and/or replace the cycling thermostat (read about
cycling thermostats in "Drying is too slow," above).
It seems to run forever
If
your dryer seems to run forever, it could be because of a clogged vent
or internal ductwork. Your dryer may have an automatic cycle that turns
off the dryer when the clothes are dry. It does this with a special
thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When
the dryer reaches the pre-set temperature, the thermostat tells the
timer to begin advancing. (If there's a moisture sensor, the timer
advances only if the moisture content of the clothing is low enough.)
The
timer advances until the interior cools, then the thermostat tells the
timer to stop advancing, and tells the dryer to start heating again.
This
cycle continues until the clothes are dry. But...if the vent is clogged,
the dryer may never reach the proper operating temperature, so it
doesn't send the signal to the timer and the dryer continues to run
indefinitely, even if the clothes are completely dry. To fix the
problem, clean the vent and/or internal ductwork.
check out this electric no heat tip...
heatman101
