Your
camera uses SD memory cards. On one edge is a slider switch: towards
the electrical contacts is the unlocked position and away from them is
locked.
Unfortunately, the switch is easy to move accidentally
and it's also easy for it to appear to be unlocked when it isn't. Like
any mechanical component it's also possible for the switch to fail.
If
the switch is in the locked position then slide it fully to the
unlocked position; if it's already in the unlocked position, slide it
fully to the locked position and then fully back again. There should be a
soft click at each end of the switch travel, if not then the switch is
definitely faulty or obstructed.
If that fails, then try looking
closely at the switch in both positions to ensure that there is no
debris obstructing its movement, if not then check the electrical
contacts to ensure that they're completely clean and grease-free. Don't
touch the contacts with your bare skin, but if the contacts need
cleaning then a cotton bud (Q-tip) moistened with a little alcohol or
methylated spirits can be used to clean them.
If you still have
no fix, then try a different SD card as yours may have an irreparable
faulty switch. If the card does prove to be faulty then on most major
brands you may be able to return them to the manufacturer for exchange:
I've found that they will often do this on a goodwill basis even if the
card is out of warranty.
If all options regarding the memory
card are unsuccessful, then you have a faulty camera and further
remedies require either a professional repair or replacement of the
camera.
I hope that my answer has been of use and has given you
additional options to fix your problem. Please take a moment to rate my
reply.
Does your card have a slide switch on the side? Move it to the unlocked position.
