Question about ASUS LCD Monitor
Turned on computer..............and the moniter wont go on..............says there is no signal? I have unpluged and repluged in and still wont work?
Posted by m_whitelock on
Ivan Godzharov
    New Friend:
  • 112 Answers
Is the PC started ?
can you try with different monitor
Posted on Sep 26, 2010
EMACHINES T5274a desktop produces continuous long beeps, it will not boot, been about 4 months since turned on, worked fine before. Monitor will not detect it either. Solutions attempted - -unplugged and...
beeping could be a number of things, memory failed processor failed. or even power supply not working correctly, memory fail will not let you turn on pc so take them out and try one card in one slot swap slots as one of the slots may have failed.
May 27, 2017 | Computers & Internet
We cannot get a sound to come out of the computer
Chec cables connections properly from the monitor speakers, it should be connected to green sound socket.
Try unplugging and replugging cables.
Sep 08, 2009 | Computers & Internet
Hanspree monitor says,''No signal input check video cable''
ask the shop for a replacement cable. it could be broken.
Mar 26, 2009 | Computers & Internet
My computer moniter wont stay blue
it sounds like it isn't receiving a signal from the PC check the cables and if you can try another monitor
Mar 16, 2009 | Computers & Internet
Will not boot
You can goto BIOS setup be pressing DEL, ESC, or one of the "F" [function} keys just before " memory count " finishes.To see what is turn 'on' or 'off' look through the menus & submenus.look for video [ ON if you have 'on board' video and off if you have a EXTERNAL video card.]
temperaty take EVERYTHING out by unpluging the wires going to computer (mother board) [cd's, h/d, floppy drive, and any other extras] You can keep them 'dangling' from e.i. floppy, cds [rom,ram,dvd etc.] keep the memory, display adapter (if you have a EXTERNAL video card) and boot up the computer.You must see the memory "count up" in DOS (black screen with numbers running on left side of screen) .At first if the machine does not turn on, replace the video card.Then after UNPLUGING a/c power put back ONE piece of equipment at a time (of cause you will replug a/c power)and rebooting.
Dec 13, 2008 | Computers & Internet
Moniter has a yellow tint
Hi...there,
Well...of course it won't work! Your backlight inverter are busted... Send it back for repaired, if you are still under warranty or you can repaired yourself by replacing those faulty capacitors from the inverter.
Oct 23, 2008 | BenQ Computers & Internet
I NEED HELP PLEASE!!!!!!! PROVIEW 19" MONITER.
Does the led on front of the monitor stay blue or does it become amber ?
If it becomes amber, then you are not getting a signal.
No harm in trying this : You can try to see if it is a contact problem.
With the monitor unplugged.
Use a small paper clip to run in and out of the blue vga plug holes a few times each to make sure they are not plugged or gummed up.
If that doesn't help and you know that your video cord is good, then I am afraid to say that more than likely there is a problem with yor video card.
If it stays blue then the signal is there but the screen isn't fully lighting up, leading to a failing power-inverter board or a bad bulb.
powerseller
bammbammfran
Oct 12, 2008 | Proview PL926WBi 19" LCD Monitor
Acer monitor lcd problem
Try the monitor with another known working computer, If ng there also, then have unit repaired under Acer warranty.
Aug 31, 2017 | Acer Professional P211 21" CRT Monitor
VGA
open it up and look for defective capacitors on the video input board and replace them. Should probably replace the 470uf caps on the power board while you are in there.
Jul 29, 2008 | Gateway FPD2185W 21 in. LCD Television
NEW EMERSON 20" LCD STERO TV/DVD- NOT WORKING
the flash was the fuse inside the set blowing it usually takes out one or two diodes in the power supply section but maybeyou got lucky and its only the fuse.
Mar 10, 2008 | Emerson EWL20D6 Television
ASUS LCD Monitor Logo
124 people viewed this question
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
