Question about Moen 2995 Chateau Three Handle Tub and Shower Faucet With Standard Valve In
Have a moen 2995 bathtub 3 handle faucet. It is stuck in the shower position. After pulling the shower knob off and the nut that holds the diverter in place, can't pull the diverter out. Thanks for the help. Chris My email address is [email protected]
Posted by jagibson on
brennahr
    New Friend:
I can't turn my knob to shower off -can you please explain how to fix it. My e-mail is [email protected]
Posted on Jan 24, 2011
The diverted valve will not turn ,it worked when installed but won't turn now .how do I replace the diverted.
The spout unscrews from the wall.Take that part off and bring it to the store to match it.Then just screw the new one on.
May 18, 2011 | Moen 2995 Chateau Three Handle Standard...
We have installed a moen 82490 one handle tub & shower unit. When we turn on the water you could shower and bath at the same time. If you pull the plug for just a shower the water to the spout stops...
If you pull the silver knob on the tub spout up, the diverter located located inside will redirect water up to the shower head and when lowered it will return the water to the tub spout. It sounds as thought the diverter is not working properly. Hope this helps..
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
Delta shower faucet loses pressure when turned all the way on (hot water). What could cause this? When it first happened yesterday, a few tiny pieces of black plastic/rubber fell out of the bathtub...
Turn off the water to the home. You need tthe stem beneath the handle. Remove the handle after locating the set screw, remove the cylindrical beauty cover, and unthread the retaining nut to access the valve stem. Take it to a plumbing supply house or home store to make certain of the match.
Oct 06, 2010 | Delta & Single Handle Shower Faucet
I bought a tub/shower valve system from lowes. When I turn on the faucet for the tub, the water comes out the tub faucet and the shower head at the same time. Is this a defective valve? Everything seems...
it sounds like the tub filler itself. When you pull the knob up it's supposed to divert the water to the shower, if it's coming out both, I'd look at that piece, inexpensive and easy to replace
Sep 13, 2010 | Moen Home
How do you turn off the moen 82691 shower valve when new.
The stem in faucet may be in faucet upside down . you can try taking handle off remove nut that holds stem take it out make sure
you turn water off before doing this.
May 02, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Shower head and bathtub faucet both running when showering
Sounds like diverter valve which is your shower handle valve is bad take it apart and check out and replace it if possible because that transfer water to shower head.
May 01, 2010 | Moen 3175 Legend One Handle Shower Faucet...
The shower control valve for my moen 2995 faucet is stuck in the shower position. how do i remove it?
Turn off water main. remove round cap on face of handle, remove screw and pull handle. After that everything else can be pulled off easily. When you get to the diverter you should be able to why its stuck.
Sep 27, 2009 | Moen 2995 Chateau Three Handle Tub and...
My Moen Chateau model 2995 shower handle will not work, will not turn to shower postion. Handle seemed to have "frozen up".
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
Thanks and Please Rate jj505
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Mar 25, 2009 | Moen 2995 Chateau Three Handle Tub and...
My 3 handle bathtub fauset [price pfisher] cycles hot and cold
You will need to either replace center "shower diverter"assembly or a quicker fix would be to remove old tub water fill spout and replace with a "pull up diverter knob" type water spout. Cost about 10 dollars Hdepot Pull Knob to divert water to shower when showering.
jthomefix
Mar 15, 2009 | Price Pfister Ashfield Widespread Bathroom...
Moen 2995 Chateau Three Handle Tub and Shower Faucet With Standard Valve In Logo
470 people viewed this question
Top Moen Plumbing Experts
john h
Bruce Robin
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
