Washing Machines Logo
Posted on Nov 06, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Spin cycle to slow, it just rotates in one direction slowly and then alternates in the other direction just as slowly. We put it on just spin and this is the result as well. It seems to be rotating as though it is in a wash cycle? Regardless of the speed chosen for the spin, the result is still a slow, alternating direction, spin?
Chris Huff
Level 3:
Top Expert:
  • Frigidaire Master 6,289 Answers
  • Posted on Nov 06, 2017
Chris Huff
Frigidaire Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2018987
Points
74913
Sounds like a failed transmission
5 Related Answers
Anonymous
  • Posted on Jan 08, 2009
SOURCE: LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Anonymous
  • 714 Answers
  • Posted on Jul 19, 2009
SOURCE: The spin cycle rotates and reverses direction at a slow speed.
try RepairClinic.com
Anonymous
  • 998 Answers
  • Posted on Aug 08, 2009
SOURCE: Noisy spin cycle while rotating at high speed to remove water.
main bearing ...yes
Anonymous
  • 17 Answers
  • Posted on Sep 07, 2009
SOURCE: when washing, my simpson encore 806 seems to only
IF YOU WANT *** CALL 01232142356436
Anonymous
  • 68 Answers
  • Posted on Sep 10, 2009
SOURCE: Washes ok, rinses ok, tub empties and rotates... but no spin
this is a problem that a lot of early neptune models had. it is most likely the wax motor on the door lock assembly is bad and needs replaced. but, almost every time that I've had that wax motor go out, it has blown the board also, therefore you also need to replace the control board. to see if the board is bad, you need to remove the 3 screws on the top of the control panel. then the panel slides forward a little and roll the top toward you. you will see the control board there. it is a large board, if the wax motor blew it, the R-11 resistor will be blown. it is easier to just look for a black spot on the board, if you do then see which one is blown and look at the numbers for that resistor. if it is the R-11 that is blown, then the board and wax motor need replaced. just a warning, the board is around $200. if you check this and that is not the problem, let me know. there are a couple other things that can cause your issue, but this is by far the most common, and unfortunately, the most expensive. good luck, shane.
What is orotation
"orotation" is rotation misspelled.
ro·ta·tion
r??t?SH(?)n/
noun
noun: rotation; plural noun: rotations
  1. the action of rotating around an axis or center."the moon moves in the same direction as the earth's rotation"
    synonyms: revolving, turning, spinning, gyration, circlingMore "the rotation of the wheels" turn, revolution, orbit, spin
    "a rotation of Jupiter"
    • the action or system of rotating crops.noun: crop rotation; plural noun: crop rotations
    • Forestrythe cycle of growth and felling or cutting of trees.
    • the passing of a privilege or responsibility from one member of a group to another in a regularly recurring succession."it has become common for senior academics to act as heads of department in rotation"
      synonyms: sequence, succession;More alternation, cycle
      "each member is chair for six months in rotation"
  2. USa tour of duty, especially by a medical practitioner in training.
    "she was completing a rotation in trauma surgery"
  3. Mathematicsthe conceptual operation of turning a system around an axis.
  4. Mathematicsanother term for curl (sense 2 of the noun).
Origin
mid 16th century: from Latin rotatio(n-), from the verb rotare (see rotate).
Maytag Nuptune... when it reaches the spin cycle, it spins, reverses direction spins , then stops. I push the start button and once again it goes through the one spin and reverse and stops again
""when it reaches the spin cycle, it spins, reverses direction spins""
So I understand do you have the washer top raised to view this action? The wash basket rotates one rotation or are you talking about the tumblers?
If you raise the washer lid and rotate the wash basket CCW the Spin direction will it rotate CCW with very little effort?
Any dC or UC error code on fail to Spin?
If you do Spin Only Cycle do you have the same results.
I would enter Service Mode and do the Quick Spin test on page 14 of the Service Manual and see what the results are.
You can get the SM from this forum once you join.
16022808 Maytag Top Load Neptune Washer Service Manual
3helpful
Machine won't spin
Hi, can you start the unit without any clothes in it, let it fill with water as usual and then observe if it tumbles in both directions during the wash cycle ? ( I don't mean the entire cycle, just long enough to insure it rotates in both direction ). Then turn it to drain and insure it drains completely, observe the spin cycle if you can and report if it only spins in one direction slowly. This will go a long way in diagnosing your Asko washer. Let me know what you find. If it only goes one way, the motor needs new brushes and possibly a complete motor if the armiture is damaged. Good luck. Macmarkus :)
2answers
Spin cycle locks up
it is the clutch and be repalced fairly easily
Washer doesn't spin
Hello skull1829 ,
Was the Clutch/One-way roller bearing changed out for dc/UC errors in your FAV6800AW/FAV9800AW?
If you start a Spin Only Cycle with an empty wash basket will the wash basket spin up CCW and complete the cycle? Lift the washer top from the base a few inches to observe the wash basket CCW rotation in spin cycle. If the clutch spring is broken or end pins of spring aren't seated the tumblers will rotate and the wash basket will rotate slowly CCW.
IF the wash basket won't spin up can you pull the front cover off and insure the motor will rotate the clutch pulley CCW in a Spin Only Cycle? Let’s try these few basic tests and get some feedback for troubleshooting.
Rich
1helpful
2answers
Kenmore Front Loading Washer Slow Final Spin Cycle
I have exactky the same problem Replaced the drum and now it will not final spin, I touched nothing else.Can't figure what could be wrong,speed board too sensitive?
It worked fine before the bearing went.
Any ideas?
Whirlpool washer front loader model LHW0050PQ
This is not a Malber machine but the following fix has worked for the Malber washer. Try unplugging the machine for at least 2 minutes. Do not just turn it off as there is still current going to the machine .This should clear the computer. If this does not work, the imbalance may have overloaded the circuit board requiring replacement.
3helpful
2answers
Maytag Performa pav2300 spins slow does not agitate
My performa 2300 makes a loud screech when it stops spinning. What is going on?
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
