Question about Oregon Scientific RMR382ABLACK Wireless IndoorOutdoor Thermometer with A
I changed batteriers and now I can't get a reading from the remote. I have hit the reset on both units. Maybe not in the righ order.
Posted by jpollock28 on
Anonymous
  • 17 Answers
I believe they ask you to press the reset button on the main unit first, but that may not be your problem. Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed. Also, make sure the units are close enough to transmit.
Posted on Oct 21, 2010
  • Diane Greene Mar 17, 2014
    they are in the same place for years
Please help me - unresponsive remote?
that being a universal remote as i was reading means they have to be paired .
turn tv off .
go into program mode , hit sumpin on remote till it turns on your tv . hit save .
its something like that always but for your remote i don't find the exact instructions.
maybe if you give us the remote model number. we can find it.
Jul 25, 2014 | Samsung UN55F6300 55-Inch 1080p 120Hz Slim...
Airwell remote
maybe the button for turn on is blocked
Dec 10, 2013 | Heating & Cooling
Vizio remote XRT302 is not working after 3 weeks of use. Any ideas besides changing the batteries?
TRY FRESH HIT BATTERIES FIRST!
I WAS ABOUT TO ORDER A NEW REMOTE, then read this thread. I went back and messed around with the remote. I checked the batteries and the had power but wee in the low yellow reading. I put in fresh hot new ones BOOM it was working just fine.
Thanks for all y'allZ commits.
Sam B.
Apr 06, 2013 | Televison & Video
I have a 433MHz cable free indoor/outdoor thermometer. It has worked perfectly for years. Just changed the batteries in the main unit and the remote. The main unit will not pick up the outside temp. I...
You have to push some buttons to tell the MAIN unit to scan, then put battery into the REMOTE, set channel, and hit reset through a little hole. And the MAIN should see it.
Sep 17, 2011 | Oregon Scientific Wireless IndoorOutdoor...
I have lost my manual for Nexxtech thermometer model6312030. I can't get it to read the outside temperature after I changed the batteries. How do I reset to make it read. Or better yet, how can I get a...
You must reset the outside unit every time you change a battery. To rest insert a paperclip into the small whole marked "reset". Temperatures should now appear on the inside or remote unit.
St. Bruno, Quebec
Nov 10, 2010 | Vacuums
I have a 32" emerson and start to change color the full screen green red white and you cant turn off , is just changing color i want know if wer out or what?
with your remote hit the arrow up and them down arrow it should then say turn power off if not you may have to repeat the proceedure and include
left to righ then turn unit off you should be alset
May 22, 2010 | Emerson LC320EM8 32 in. LCD TV
Not picking up outside unit
you have to have the station and the sencers close to each other when you put in the bats and then give them about ten mins
Nov 08, 2009 | Sport & Outdoor - Others
My 2004 Malibu Remote is malfunctioning
I would start by buying a new remote, it will be the cheapest and fastest way to determine what your problem is. You can either get one from a GM dealer or on e-bay. I prefer e-bay because the unit is usually cheaper and you can find sellers that will include programing instructions with you purchase. The GM dealer will normally charge you $25.00+ extra for programing.
Aug 26, 2009 | 2004 Chevrolet Malibu
Lamp clock reset
The only way to reset the lamp timer is with the LG programmer remote, however resetting the lamp timer does not affect the picture quality. If you need a part # for the remote let me know. Maybe you can find an auth. service center who will let you use the remote. If they do, simply power the unit up and when running hit the instart button on the programmer remote and after the menu comes on the screen simply hit the offstart button. The unit will shut of and when you power it again the lamp timer will be reset.
Nov 04, 2007 | LG RU-44SZ61 44" Rear Projection...
Oregon Scientific RMR382ABLACK Wireless IndoorOutdoor Thermometer with A Logo
1,729 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
