Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Start your pc immediately tapping f8 it leads to a dialog box.. in that select safe mode,, it goes to windows safe mode
Hi Users who may not be able to boot into normal mode, or are not able to troubleshoot their computer properly, may need to boot into Safe Mode bypassing normal windows settings and startup programs and allowing the user to fix their computer If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration. Additional information about this mode can be found on document CH000626. To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key. Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu. Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen. Windows Advanced Options Menu Safe Mode Enable Boot Logging Start Windows Normally Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows simply restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode. Microsoft Windows Vista and Windows 7 usersIf you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration. Additional information about this mode can be found on document CH000626. To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key. Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu. Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen. Choose Advanced Options for: Microsoft Windows Vista Safe Mode Enable Boot Logging Start Windows Normally Description: Start Windows with only the core drivers and services. Use Once you're done in Safe mode if you want to get back into Normal Windows simply restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode. To get into Windows 98 / ME Safe Mode, as the computer is booting press and hold your "F8 key" on the top of your keyboard or press and hold the left or right Ctrl key as the computer is booting. If done properly you should get into the "Windows 98 / ME Startup Menu" similar to the below screen example. In this menu choose option 3 by pressing the 3 key and press enter. Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu. Microsoft Windows 98 Startup Menu 1. Normal Enter a choice: 1 Once you're done in Safe mode if you want to get back into Normal Windows simply restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode. To get into Windows 95 Safe Mode, as the computer is booting, when you either hear a beep or when you see the message "Starting Windows 95", press your F8 key on the top of your keyboard. If done properly you should get into the Windows 95 Startup menu similar to the below screen. In this menu choose option 3 by pressing the 3 key and press enter. How do I get out of Safe Mode? From Windows Safe Mode click Start / Shutdown and restart the computer. This should start the computer automatically back into Normal Mode. Note: Many users believe that they are still in Safe Mode because the colors or video may not look correct. Unless in the corners of the screen it says "Safe Mode", you are not in Safe Mode. For information on how to setup your video card resolution, see document CH000190. If you are rebooting the computer and it is rebooting back into Safe Mode (it does say "Safe Mode" in each of the corners), it is likely another problem exists with Windows preventing it from loading into Normal Windows. We recommend you see our basic troubleshooting section for additional ideas that may help to resolve your issue. Which Safe Mode option should I choose? Users who are running later versions of Windows will get several different options for different types of Safe Mode. For example, you may have options for "Safe Mode", "Safe Mode with Networking", and "Safe Mode with Command Prompt." Below is a brief description of each of these different modes. Safe Mode The basic Safe Mode option is usually what most users will want to choose when troubleshooting their computer. This is the most basic Safe Mode option and has no additional support. Safe Mode with Networking For users needing access to the Internet or the network they're connected to while in Safe Mode users may wish to choose this option. This mode is helpful for when you need to be in Safe Mode to troubleshoot but also need access to the Internet so you can get updates, drivers, or other files to help troubleshoot your issue. Safe Mode with Command Prompt This Safe Mode would also allow you to have access to the command line (MS-DOS prompt).
Reason:
Please select an option:
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Reboot
Return to OS Choices Menu
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
when you cannot boot after installing a new device or driver.
2. Logged (BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
THANKS....
With Regards......
Vaishu
