Question about LG 42LC2D 42 in. LCD HDTV
How can use to LG LCD tv in wall hang - LG 42LC2D 42 in. LCD HDTV
Posted by darshit6682 on
Anonymous
    President:
  • 2,047 Answers
First you get the wall hanger. Screw one part to the wall. And then screw the other part to the TV. then you hang the TV on the part screwed to the wall.
Hope this solution has been helpful?
Posted on Sep 26, 2010
2 Related Answers
Anonymous
  • 5 Answers
SOURCE: i'm trying to hang my tv "Lcd Thomson 32E92NH22"
in the manual there is now screw size specified. there is only a notice about VESA mounts.
here is a link to the manual, so you can have a look yourself: http://safemanuals.com/user-guide-instructions-owner-manual/THOMSON/32LB130S5-_E
greets, b.
Posted on Mar 01, 2011
thevolatile1
SOURCE: I have a Lg 42" lcd tv (42LG3000) TV is wall
White screen with good audio. before buying pcbs & such. try my repair method.. you need to get the lcd unit off the facia & then remove the front lcd metal frame. at the top of the screen you have 2 thin pcbs - chances are that the ribbon cable got at least one track unbonded. first off put some double sided tape under the pcbs to stick then to the frame - that'll take the bend out of those pcbs !! next put cellotape over the ribbon cables. i then cut 6 pieces of sponge 15mm thick & wide as the ribbon cable & glue to the tape on the ribbon at what would be the top edge of the screen (covering the point where ribbon meets pcb).. put the metal frame on top edge first to keep the sponge straight !! put it back together & fire it up. if it still aint working you may need a tcon pcb (little square one at the top). this fixed my 42lg3000 but can work on others with same fault !!
Posted on Dec 19, 2011
Hello, I have a lg lcd monitor. w1941s model. when I start my computer, it work for sometime. then it goes blank showing only the LG logo. then the power button doesnot work. it hang up glowing. again
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
I have a LCD TV, model 42LG6***. I fixed it on the
it's more than likely that the wall mount you used for installation was not an LG mount. Do you have any paperwork indicating the brand of wall mount you used. If this was professionally installed, then check with your installer. He may have such a key.
I'm trying to hang my tv "Lcd Thomson 32E92NH22"
greets, b.
3helpful
3answers
LG 42" tv LCD pannels inside tv have a cracked
The set needs a new LCD if it looks cracked and swirly, the colors all run together in the area of the crack don't they! If it is cracked it can't be fixed. you can replace the lcd but I am not sure if a warranty will cover a cracked screen or not. You will need to contact LG and be very nice to them and see if they will honer the warranty on this.
Need to remove the bottom attached to tv to mount tv to wall
Firstly, before you unscrew anything, lay the screen face down on a mat on a table/desk with the stand hanging off the edge of the table. This will ensure nothing moves without you wanting it to.
There's four screws to remove, two from each leg. Two of them are above where the mains plug goes in, and two above the computer display input socket. Stand should slide out once these have been removed.
3helpful
How do you take the base off the bottom to hang the TV?
On the back of the tv located at the very bottom where the stand meets the base of tv there are from 4 to 6 screws that hold it in place. I am including a link to the tv's manual. The instructions for the base are located on p.13. If this helps please rate me. I do not get paid but like to help.
http://www.lg.com/us/tv-audio-video/televisions/LG-lcd-tv-42LG30.jsp
Power won't stay on
hello. you are not alone, this is a common problem with alot of new lcd and plasma tv's since they operate with high internal voltages the circuts have built in protection. any slight power fualt or short in the circut will cuase a sos or shutdown. may be a number of different reasons or even a shorted fuse.
it needs to be checked you have a power issue.
some models if there is a blinking led the number of blinks indicates the fualty area.
your tv needs service.
hope this helps
LG 42LC2D 42 in. LCD HDTV Logo
Ekse
