SomeHotpoint's are designed to go into test mode when the start button and the on/off button are pressed at the same time. If you are stuck in Test mode, simply hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see 'D:end' (or similar message). Now try a normal wash programme again and hopefully it should be fine. If it goes into test mode by itself, then it may be an indication that there is a real fault, or a faulty programmer board. hope this helps.
SOURCE: Hotpoint ultima wf860
this problem occurs when you acidently lean on the start and on/off buttons at the same time,it is not a programing fault that is designed to occur yearly.
but the listed solves do work.
