The Sanyo codes appear to be 620, 801, 931 . Turn on the TV, press and hold Set-up until the light comes on and enter the three digit code. Check if the TV responds (volume, channel). If not try the next code.
To search all codes: turn on the TV, press and hold the Set-up button. Then press Channel + slowly but repeatedly until the channel changes. Press Enter (if you overshoot, press Channel - to before pressing enter.) To record the code, turn on the TV, press and hold Set-up, then press Set-up again and type 0-9 individually until the indicator light blinks. That is digit 1, repeat the search from 0-9 for the other two digits.
If your TV was released ~6 months before the remote was programmed or is newer than the remote, then the code you need may not be in the remote's programming. In that case, you need a newer remote, one of the remotes that is programmable (USB to a computer), or a remote specific to your TV (try remotes.com and search on the TV model - leave off the brand name).
I hope this helps.
