Question about Epson Stylus Pro 7600 InkJet Printer
My printer says service required 00010005 can anybody tell me what does that mean? Also if anybody is intrested website lpscomputer.com has downloadable service manual for some printers. (except for my printer)
Posted by mdmstructure on
srmarmota
Service req 00010005
Posted on Jun 27, 2011
What does "service req. - 00010005" on epson 4880 printer mean?
http://largeformatrepairs.co.uk/errors/epson/sp4880/00010005/
Quoting from the link above:
Service Call Error 00010005 CR Motor Out Of Step During CR Motor operation, there may be a case where the encoder pulse signal within the specified range is not input within a specified period of time or the pulse width is extremely long or short. In such a case, the CR Motor is judged to be out-of-step, so that this message is displayed and the printer stops operating.
This error occurs on the Epson Stylus Pro 4880 large format printer and is not a routine maintenance request.
May 02, 2018 | Epson Office Equipment & Supplies
What does the symbols on the printer mean
If your intrested of that find a service manual or a user manual and you will find out , but if i suspect we'll your printer has a problem whith the main board a service man might try to change the bin info located on the chip from pannel
Mar 30, 2014 | Lexmark E232 Laser Printer
Giving me a Sevice Error 00010005
  • This error means there is a problem with your printers carriage operations
  • Check the carriage and the cartridges.
  • Remove anything that could be in the way of the carriages.
  • Check the cutter cap which if may also be a cause.
Thank you!
Sep 28, 2011 | Office Equipment & Supplies
Error Code 08:11 HP z6100
The 08 portion of the code indicates FRONT PANEL. the :11 is an action code requesting RESEAT, CLEAN meaning you should reseat the connectors at the display and on the other end at the electronics. Cover removal is explained in the service manual which can be downloaded here: www.lpscomputer.com/ec/manuals.htm
Oct 28, 2009 | HP Hewlett Packard Designjet Z6100 InkJet...
DESIGNJET 755cm ERROR MESSAGE: TURN OFF PLOTTER CHECK PAPER PATH. THERE IS NO OBVIOUS BLOCKAGE TO PAPER PATH
If there is no obvious obstruction in the print head path, the most likely problem is a worn carriage belt. Open the front lid and check for rubber crumbs under the carriage belt. If there are crumbs, the belt is disintegrating and needs to be replaced.
The service manual can be downloaded from: www.lpscomputer.com/ec/manuals.htm and the parts are available at: http://www.lpscomputer.com/c-736-designjet-1050c-belt.aspx
Oct 10, 2009 | HP DesignJet 1050c InkJet Printer
Hp desinejet ploter belt
Follow the procedure for replacing the carriage in the service manual.
he manual can be downloaded here: www.lpscomputer.com/ec/manuals.htm
The repair parts and repair kits can be purchased here: http://www.lpscomputer.com/c-637-designjet-250c-330-350c.aspx
Jun 04, 2009 | HP DesignJet 350c InkJet Printer
Printer error - call for service, 9-911 what does this mean?
It will be best to run diagnostic tests on the printer and especially the electronics before coming to any conclusions. My first guess would be that some part of the memory went south. The test procedures are in the service manual which can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
Apr 16, 2009 | Xerox Tektronix Phaser 7700GX Laser...
Epson Pro 7600 Service required error
You need to be able to clear the counters in the printer that tell the printer to stop working.
In order to do that you must
1. Turn printer off
2. you must hold down the "Paper Source, Paper Feed, Select Feed, Cut/Eject" buttons all at the sime time while you turn the printer back on.
3. From there navigate through the menues to clear the counter that pertains to you or all.
(Error 00000101 is pertains to the print head motor)
Word of warning -
Those counters can be a pain as they cause the printer to stop working however you do need to get your printer serviced by a tech as soon as you can because the error is a warning, reset the counters lets you finsih a job, but if it goes unserviced too long it will actually break down all togther.
So even after you rest the counters you absolutly must get your printer serviced soon.
Apr 17, 2008 | Epson Stylus Pro 7600 InkJet Printer
Epson Stylus Pro 7600 InkJet Printer Logo
1,835 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
