Ice maker won't work, it worked fine for 15 hrs, no water in water well. It use to make a sound as the water came on to make ice. Noe I don't hear anything. The bar in the machine is down in the ice making position.
P
Is water getting into the ice tray of maker? If not check for the water solenoid's proper operation. Is freezer temp at least 10 degrees or less? If not, the ice maker will not work. If ice in tray then perhaps the heater element is not working to melt it a tad ans allow the fingers to pudh the ice out and into the tray.
You can get those suckers for about 40 bucks new on ebay eBayeBay
First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
the water that is frozen in the fill tube could have come from the old water valve that you replaced ,you got to get the ice out, the easiest way ,though not the fastest ,is to unplug fridge for 24 hrs . and leave the doors open to let it defrost, the plug back up and hopefully in 5 or 6 hrs you'll have ice
Freezer too cold and not much water. When it is empty of ice check the water level in the ice tray. Probably not even halfway up. Unplug fridge for 8 hours and plug it back in. Need more help please live chat. If this has helped, please rate as fixya.
My ice maker jams up once in awhile. I use a hair dryer aimed at the mechanism on high. Avoid close contact air flow directly on plastic parts. Takes 2 to 3 minutes.You will hear machanism pop several times, then wire raise up and drop.
