Question about Mitsubishi Heating & Cooling
My MSY-A17NA UNIT will start functioning normally then after about five minutes it stops blowing air and the operation led signal starts flashing. When both the operation and indicator led's are on the unit works properly. After I shut it down and start it up again the unit works fine. How can I get it to stop shutting down every 5 minutes? I'm in Hawaii and it is Hot here! Please help.
Posted by spm4life01 on
D. Floyd Kolb
  • Mitsubishi Master
  • 43,501 Answers
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Posted on Sep 26, 2010
My panasonic air conditioner model CF-E24GKR is does not appear to be working the green power light is flashing and it is blowing cold air
14.2.2 To Make a Diagnosis:
1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
When you have the error code you will be able to diagnose the fault.
Jun 06, 2017 | Panasonic Heating & Cooling
I have two flashes on the timer light of my indoor unit of Fujitsu Inverter ASU9RLS
Serial signal (reverse) error, at operation start up. operation led - off, timer led - 2 flashes, coil dry led - off, check wire between indoor and outdoor
Jul 10, 2015 | Fujitsu ASU9RLS2 Single Zone Wall Ductless...
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
• Although Timer LED goes off when power supply is turned
off, if the unit is operated under a breakdown condition, the
LED will light up again.
• In operation after breakdown repair, the Timer LED will no
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
1. Timer LED start to blink and the unit automatically
2. Press the CHECK button on the remote controller
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by
pressing the CHECK button continuously for 5 sec-
onds or without any operation the remote control for
30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, we can work out what to do next.
Mar 27, 2015 | Panasonic Heating & Cooling
Mr slim indoor fan shuts off
Might change the battery on your control. I wish these had a hard wire thermostat not a big fan of the remote can be confusing.
Mar 19, 2013 | LG LS-L1210CL Mini Split Air Conditioner
My nissan 95 truck won't start. the battery is ok. once it wouldn't start and i put it in neutral then back to park and it started right up. where is the neutral safety switch located? I heard...
I think your reverse to park trick was a fluke,, I assume it turns over but since it is a 1995 you dont have a OBD 2 in the vehicle.
How to pull ECU error codes for 87-95 Pathfinders and Hardbody pickups:
The ECU is under your passenger's side seat. You can gain access to it by simply sliding the seat all the way forward and removing the plastic cover from the ECU. You can also remove the seat if you want, it makes access a little easier.
The VG30i ECU's have a tiny toggle switch on the side of the ECU with a small snap-in switch cover that must be utilized to select the diagnostic mode of the ECU. The 4-cylinder ECU and the VG30E ECU has a slotted switch that turns 1/4 or 1/2 turn clockwise and counterclockwise to do the same task. Some early 4-cyl HB ECU's have the switch as well. In any case it will have one or the other.
For 4-cylinder:
1. Turn the ignition switch on, but do not start the engine. All of the lights in the dash should be on.
2. Turn the 'diagnostic mode selector' screw on the ECU fully clockwise. The check engine light will go out. Wait 5 seconds, then turn the screw fully counter clockwise.
3. The check engine light will then begin to flash the trouble code. (number of long flashes is the 1st digit, number of short flashes is the 2nd digit)
4. To clear all stored codes and turn the check engine light off, turn the screw fully clockwise while it is in diagnostic mode. Wait 5 seconds, then turn the screw fully counter clockwise.
5. To keep the codes stored, simply turn the key off as the check engine
light is flashing and the ECU will keep all stored codes and the check engine light will remain on.
For V6:
2. For VG30i: There is a little plastic tab you pull off of the side of the ECU(facing the door). A small toggle switch is behind it with 2 positions, "ON" and "DIAGNOSTICS". Using a small screwdriver or tool, move it to the diagnostics position. The red and green LED's on top of the ECU will blink simultaneously. One time, pause, then 2 times, three times, pause...so on for each mode, 1 through 5. Mode 3 is the most commonly used mode and will yield the ECU trouble codes you need to figure out what's going on with your engine.
For VG30E with slotted switch: Turn the 'diagnostic mode selector' screw on the ECU fully clockwise. The check engine light will go out. Wait 5 seconds, then turn the screw fully counter clockwise.
3. After it blinks both LED's 3 times move the toggle switch back to the on position. After about five seconds it will start to output out the diagnostic codes as with the 4-cylinder ECU. Note each code as it is displayed, the red LED flashing once for 10's, and the green LED flashing once for 1's. Meaning: One red flash and two green flashes means code 12.
4. To clear the ECU of any trouble codes, move the switch to the "DIAGNOSTICS" position then back to the "ON" position and turn off the key.
1986.5-1995 Nissan ECU Flash Codes(all engines)
11 Crank Angle Sensor/Camshaft Position Sensor.
12 Air Flow Meter/Mass Air Flow Sensor.
13 Engine Coolant Temperature Sensor.
14 Vehicle Speed Sensor.
21 Ignition Signal.
22 Fuel Pump.
23 Idle Switch.
24 Throttle Valve Switch.
25 Idle Speed Control Valve.
28 Cooling Fan Circuit.
31 ECM.
32 EGR Function.
33 Heated Oxygen Sensor.
34 Knock Sensor.
35 Exhaust Gas Temperature Sensor.
36 EGR Control-Back Pressure Transducer.
37 Knock Sensor.
38 Right hand bank Closed Loop (B2).
41 Intake Air Temperature Sensor.
42 Fuel Temperature Sensor.
43 Throttle Position Sensor.
44 ECCS Normal Operation.
45 Injector Leak.
47 Crankshaft Position Sensor.
51 Injector Circuit.
53 Oxygen Sensor.
54 A/T Control.
55 No Malfunction.
63 No. 6 Cylinder Misfire.
64 No. 5 Cylinder Misfire.
65 No. 4 Cylinder Misfire.
66 No. 3 Cylinder Misfire.
67 No. 2 Cylinder Misfire.
68 No. 1 Cylinder Misfire.
71 Random Misfire.
72 TWC Function right hand bank.
73 TWC Function right hand bank.
76 Fuel Injection System Function right hand bank.
77 Rear Heated Oxygen Sensor Circuit.
82 Crankshaft Position Sensor.
84 A/T Diagnosis Communication Line.
85 VTC Solenoid Valve Circuit.
86 Fuel Injection System Function right hand bank.
87 Canister Control Solenoid Valve Circuit.
91 Front Heated Oxygen Sensor Heater Circuit right hand bank.
94 TCC Solenoid Valve.
95 Crankshaft Position Sensor.
98 Engine Coolant Temperature Sensor.
101 Front Heated Oxygen Sensor Heater Circuit right hand bank.
103 Park/Neutral Position Switch Circuit.
105 EGR and EGR Canister Control Solenoid Valve Circuit.
108 Canister Purge Control Valve Circuit
ECU Diagnostic Mode Procedures
Mode I - Exhaust Oxygen Sensor Monitor
Use Mode I to determine if the Oxygen Sensor is functioning properly.
Warm the engine to normal temperature.
Run the engine above 2000 RPM under no load while looking at the ECU.
Make sure the GREEN LED goes on and off more than five times during ten seconds at 2000 RPM.
If the number of flashes are not more than five, replace the oxygen sensor. If the LED does not flash, check the sensor's circuit.
Mode II - Mixture Ratio Control Monitor
Use Mode II to determine if the air/fuel mixture is cycling correctly.
Warm the engine to normal operating temperature.
Turn the dial on the ECU fully clockwise (or if you have a switch, turn it on).
After the LED flashes twice, turn the dial fully counter clockwise (or turn the switch off).
If the RED LED blinks simultaneously with the GREEN LED, the air/fuel mixture is cycling properly.
If the RED LED stays off, the mixture is more than 5% rich.
If the RED LED stays on, the mixture is more than 5% lean.
If the RED LED stays on or off above 2000 RPM, complete the diagnostics before beginning repairs.
Mode III - Stored Fault Code Reporting
Use Mode III to retrieve all stored trouble codes in memory.
Use the above posted procedures.
Mode IV - Switch Operation Monitor
Use Mode IV to determine if the Throttle Position Sensor (TPS), Starter circuit and/or Vehicle Speed Sensor (VSS) are in proper working order.
Turn the dial on the ECU fully clockwise. After the LED flashes 4 times, turn the dial fully counter clockwise.
Make sure the RED LED is turned off.
Make sure the RED LED turns on when depressing the gas pedal. If not, check or replace the Throttle Position Sensor.
Make sure the RED LED turns on when turning the ignition key the START position. If not, check or replace the starter.
Drive the vehicle with the ECU unbolted and within view. Make sure the GREEN LED turns on when speed is 12 MPH or more. If not, check or replace the Vehicle Speed Sensor.
Mode V - Real Time Diagnostic Function
Use Mode V to determine if the Crankshaft Position Sensor (CPS), Mass Air Flow Sensor (MAFS) and/or Ignition signal are working properly.
Start engine.
After the LED flashes 5 times, turn the dial fully counter clockwise.
Make sure LEDs do not flash for 5 minutes when racing or idling the engine.
If it flashes, count the number of flashes, turn engine off, and see the following 3 paragraphs. Perform real-time diagnosis inspection and repair or replace malfunctioning part if present.
if LEDs do not flash for 5 minutes, turn engine off.
If the RED LED flashes 3 times for 1.5 seconds, check the Crankshaft Position Sensor. Check the harness continuity at CPS when the engine is stopped. Inspect the harness for dust and clean if necessary. Check the pin terminal at ECU for bends and remove them as necessary. Reconnect harness and recheck continuity. During real-time diagnosis, tap the harness connector or component and check if trouble code is displayed. If so, replace terminal.
If the GREEN LED flashes twice-3 times for 0.5 seconds, check Mass Air Flow Sensor. Check the harness continuity at MAFS when the engine is stopped. Inspect the harness for dust and clean if necessary. Check the pin terminal at ECU for bends and remove them as necessary. Reconnect harness and recheck continuity. During real-time diagnosis, tap the harness connector or component and check if trouble code is displayed. If so, replace terminal.
If the GREEN LED flashes 4 times for 0.2 seconds 3 times, check the ignition signal. Check the harness continuity when the engine is stopped. Inspect the harness for dust and clean if necessary. Check the pin terminal at ECU for bends and remove them as necessary. Reconnect harness and recheck continuity. During real-time diagnosis, tap the harness connector or component and check if trouble code is displayed. If so, replace terminal.
Hope this helps...
__________________
Feb 11, 2018 | 1995 Nissan Pickup
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
Found indoor unit running and calling for cooling,outdoor unit was off and came on while hooking up to low side,low side pressure was at 0-1psi.liquid line leaving was frosted up.shut off outdoor unit and...
Hello Sounds like a restriction/clog if the unit is (pumping down) .try adding freon when the compressor cools off & starts again.See if the low side #s improve.Make sure the service valves are open.
Aug 20, 2010 | MSY-A17NA Air Conditioner
The main fan on indoor unit gets clogged with dirt. It is hard to access and very hard to clean. Are there any tricks? MSY-A17NA
Sometimes the best way is to try and vaccum off as much as you can and then blow off the rest. Unfortunatly there isn't an easier way. You try and modify something that you can attach to the vaccum that can get into tight spaces. You might try some small tubing taped onto the end of the vaccum.
Mar 20, 2009 | Mitsubishi MS-A09WA Split System Air...
LG Inverter A/C Unit LSJ092V-3
I would first check the condensate drain pipe. This can be done by blowing back into the drainpipe from outside. Not to worry it is not dirty or dangerous. Also make sure that your air filters are clean.
Feb 19, 2009 | LG LS-L1210CL Mini Split Air Conditioner
My Honeywell rth230b thermostat continues to give me a flashing snowflake signal and will not allow the AC to turn on.
Your snowflake should flash for about five minutes, that is the time delay built into the thermostat. It should stop after that and your system should begin to function.
May 28, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
171 people viewed this question
Top Mitsubishi Heating & Cooling Experts
Marvin
Marvin
NOEL
NOEL
Vernon Taylor
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
