Question about Samsung SGH-i900 Omnia Unlocked Cellular Phone
Hi, I'm alan . when I try to connect on my macbook using syncmate by wifi connection,syncmate software ask for the IP address or hostname of my device,I ave no idea where to find those info on the omnia i900 for that wifi connection....thnx and please kindly help with some setting to make it work....omnia nice phone.
Posted by mapigoalan on
Anonymous
    New Friend:
Hi, once you launch SyncMate driver on your mobile device you will see this information. You will find all details in this article http://wiki.eltima.com/user-guides/syncmate-macos/synchronization-with-devices.html
Posted on Sep 29, 2010
HP Envy 5530 first some time ago stopped copying and scanning busy it said. Yesterday started with everything flashing showing: Code# C2EBA341 I uninstalled the printer.
why not reload the software from HP.
that be like first
no OS stated,, cept MAC.
I had tried, so did it down load, fully and the fully install, you said only TRIED !
ah wireless, that is hard
does thie printer work , to other PC< or direct.>>>>??
lean to diagnose, we start simple the work to hard, (wifi)
no one here can do that for you,its you deal.
this printer does 3 ways
wireless
wireless direct
wired ethernet never
usb
so does USB work , on your pc or others/. then the printer is ok
and you need wifi training, (not easy most times)
you never once side wifi direct or to wifi router (indirect)
the router, is best. so what router is it.???
did you set up a reserved, IP address, for your printer?
let me tell you this is always best, then you write doen that IP
on paper stick it to the side of the printer, so you know where to connect.
did you do the steps for manually wifi setup to the router in the manual.>
the HP software will attempt to find the rounter, and find and free
DHCP IP address, and can do so, but many times this fails.
ON my fancy router log in and see it. in the IP connected page.
if missing then the HP is not connected, telling which end is bad side
printer
or the MAC end. APPLE END.
IF You knew all that you can even ping the printer. from any PC on the LAN
why not use USB first. or all the time.
if sharing the printer is necessary ,start with USB
then get the printer on its own reserved IP, ending the hardships.
then sharing is next.
May 28, 2017 | HP Computers & Internet
No internet connection
Check if you can , by pass the wizard and set the connection manually. Let me find more details for you
Thanks
proton
Jul 24, 2008 | NetGear RangeMax WPN824 Router
I have had Wi Fi on my Kindle Fire and now it will not connect and keeps asking for an IP address
When you connect to Wifi and if it shows "obtaining IP address" means it is searching for the IP address of the wifi sender...
when you connect to internet it is done through IP address so your phone is tying to locate an IP address with which it can connect
to the internet. Below are the steps to connect your device to Wifi:
Applications-->settings-->turn Wifi ON-->select the wifi that you want to connect from the list displayed-->enter the network password(if it asks for) -->connected Another easy way...just open the chrome app in your phone and try typing in some website like google.com when it tries to connect a pop up will appear "try connecting to WiFi ..mobile data will incur charges.." something of that sort...and you can click connect to wifi...and automatically it will detect the wifi that is around your location. You can check for your IP address through Ip-details.com
Jul 12, 2015 | Amazon Kindle Fire HDX 7
I keep trying to hook to my wifi and it wants to change my IP address continuously. I had to change the settings to "static" and type in my IP address. Unit connects initially and then reverts to an
Keep the router to supply IP address using dhcp mode. Increase the lease time to 24 hours and don't forget to bind your device mac address with the dhcp IP in the router. This way it will always get the same ip from the router.
Dec 30, 2014 | Computers & Internet
How can I connect WiFi router to office network?
On your computer wireless card configuration, try changing the fixed IP address to the following -.
In the TCP/IP Protocol set Obtain an IP address automatically and set Obtain DNS server address automatically.
Jun 25, 2012 | D-Link DIR655 WiFi Router 4port switch...
HI I HAVE BOUGHT THIS ROUTER BUT ARE HAVING PROBLEMS GETTING MY COMPUTER TO FIND IT, THE WAN LIGHT COMES ON GREEN WHEN CONNECTED TO THE DSL BUT WIFI LIGHT IS ORANGE. I AM USING A MACBOOK SO SETUP MAYBE...
do you have fixed IP address on your computer. ? that might be the reason if its diffrient from the routers. if thats not the case give a fix ip address to your computer which is in the range of your router and try to connect it.
examples if your router have default ip adress : 192.168.0.1 give your computer address as : 192.168.0.2 and subnet mask 255.255.255.0 default gatway : 192.168.0.1
Aug 10, 2010 | Edimax Computers & Internet
How to create subinterfaces on a 3845 series cisco router? I am trying to setup a trunk port for VLAN configuration. Thanks
Its like router on stick configuration??enter the interface which you have to configure and in that interface as mentioned below
Hostname(config)#interface FastEthernet0/1
Hostname(config-if)#no ip address
Hostname(config-if)#no shutdown
Hostname(config)#interface FastEthernet0/1.1
Hostname(config-if)#encapsulation dot1Q 1 native
Hostname(config-if)#ip address x.x.y.y < subnet mask >
interface FastEthernet0/1.2
Hostname(config-if)#encapsulation dot1Q 2
Apr 09, 2010 | Cisco 3845 Integrated Services Router...
Can you tell me what an ip addresse is im trying to connect to xbox live and it keeps asking for ip addresse
Every device connected to the public internet is assigned a unique number known as an internet protocol (IP) address. IP addresses consist of four numbers separated by periods(also called a 'dotted-quad') and look something like 127.0.0.1
since these numbers are usually assigned to internet service providers with region based blocks, an IP address can often be used to identify the region or country from which a computer is connecting to the internet. an IP adress can sometimes be used to show the users general location because the numbers may be tedious to deal with, an IP adress may also be assigned to a host name, which is sometimes easier to remember hostnames may be looked up to find IP adresses,and vice-versa. at one time ISPs issued one IP adress to each user. These are called static IP addresses. beacuse there is a limited number of IP adresses and with increased usage of the internet ISPs now issue IP adresses in a dynamic fashion out of a pool of IP addresses (using DHCP). these are referred to as dynamic IP addresses. This also limits the ability of the user to host websites mail servers, ftp servers, etc. in addition to users connecting to the internet with virtual hosting,a single machine can act like multiple machines (with multiple domain names and IP addresses).
Jan 30, 2010 | Microsoft Xbox 360 Elite Console
My Samsung Blue Ray Disc player with a Samsung WIS09ABGN LAN adapter won't connect with my Apple Express WiFi and MacBook Pro. How do I make it work?
This disc player is get an IP address.
1) If connected to MacBook Pro with an ethernet cable, it will get an IP address something like 169.254.xx.xx but it will communicate with the laptop
2) If connected the Blu-ray disc player using Apple Express, you need to create an Ad-Hoc wireless network to share media and stream it.
**But ensure that the in-built firewall on a MAC is completely turned OFF or else it should be properly configured.
Jan 14, 2010 | Computers & Internet
Belkin wired voip iad not connecting to internet with macbook
Try opening the Network Control Panel on the MacBook. Select the TCP/IP tab, then click Advanced. Note the list of IP address numbers. Click the "Renew DHCP Lease" button and see what changed. Most likely all of them did, in particular the "Internet Gateway" and "DNS server" addresses. The first is the connection between the D-Link router and your ISP, and the other addresses are for servers that translate your web browser URLs into the IP addresses for the web sites you want to see. The Gateway and DNS server addresses have to match those in the upstream router(s). The routers must have current IP addresses assigned by the routers upstream, and any client computer must have a current address assigned by the first route upstream. You can check into this by logging in to the webpages for your routers and examining the status reports.
Apparently one of the devices in the chain fails to obtain a new IP address when the D-Link router is powered on. I suspect it is the Belkin router. A computer with an expired DHCP lease will probably be using the Internet gateway IP address assigned to the D-Link router when it was on before (in a busy neighborhood, that address would have been re-assigned to some other household). The Windows system may be sending a request for DHCP renewal up the line, which triggers the Belkin router to ask for the same from the D-Link unit, but it may be ignoring the signal from the MacBook or not getting one.
If the MacBook successfully gets online with a manual Renew DHCP Lease request, obtain the owner's manual for your Belkin router (find the model number, then go to the Belkin support/downloads page for that model). See what settings are available to automate the DHCP renewal process.
Jul 10, 2017 | Belkin Computers & Internet
Samsung SGH-i900 Omnia Unlocked Cellular Phone Logo
171 people viewed this question
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
