Share by EmailQuestion about Westinghouse SK-32H540S 32 in. LCD TV
2 AnswersTV goes blackMy TV will turn on and show the picture for 5 seconds and then go black as the sound continues. I have unplugged the TV and reset my dishnetwork receiver.
Posted by rajajay72 on Jun 25, 2009
Talk to a Technician1 CommentFlagMoreAnonymous Mar 15, 2014
tv turns on screens goes black unplug it and plug it back in and no picture or volumeĆ
stampco8
Expert44 AnswersI had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections.
http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part #
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
joeroc123164
Contributor16 AnswersThe power and inverter boards are combined in this model. If you inspect the three transformers that power the lamps you will most likely see that one or more is deformed (looks like it is slightly melted). You will also notice that the board under the transformer is discolored due to heat. This board is also known for bad solder connections. The actual repair would be to replace the transformer (T1, T2, or T3) but as of writing this I have not found that part available without having to buy the complete board.
Posted on Mar 23, 2010
ĀæPuedes darnos el nombre de tv y modelo, por favor? Puede ingresar esa informacion usando el menu Comentario.He copiado una pregunta anterior de FIXYA como ejemplo de la reparacion de un modelo de televisor con un problema similar.
