GE WWSE5200B Top Load Washer Logo
Posted on Sep 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wont spin out,starts spin cycle then stops - GE WWSE5200B Top Load Washer
Anonymous
Level 3:
  • GE Master 43,501 Answers
  • Posted on Sep 25, 2010
Anonymous
GE Master
Level 3:
Answers
43501
Questions
0
Helped
10842933
Points
101584
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
1helpful
Have Siemens WFXD8400UC UltraSense Plus washer won't spin. "Auto Load Adjustment" message. Motor already replaced.
ck out this........
https://www.how-to-repair.com/help/faqs/siemens-washer-wfxd8400uc-wont-spin/
Machine worked fine to start with . Then stopped. Will fill water but drum wont turn on a wash cycle. And wont spin on spin cycle.But Belt seems fine. Can you help.
The pump needs to be replaced. The pump controls the agitation for the wash cycle, also controls the tub for draining & spinning after the wash & rinse cycle. The belt has nothing to do with it. Pump is very simple to remove & replace, and not too expensive, it's plastic.
INDESIT WIB101 WONT SPIN
Have you checked the lid safety switch? Even if it doesn't spin, the cycle timer will continue.
1helpful
I have a Legacy SAV405DEWW machine wont run
I just had the same problem. The washer would stop about 2/3 through the spin cycle and not start again. Replaced the timer. That did NOT solve the problem.
2helpful
Washing machine wont spin the water out.
IT IS VERY POSSIBLE THAT YOU HAVE A BAD OUT OF BALANCE SWITCH. THE MACHINE WILL NOT GO INTO A HIGH SPEED SPIN IF THE SWITCH IS BAD.
6helpful
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
3answers
Wont Spin
Hi Vixxy, Which lights flash when you hear the beeping?
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
