Do you feel very cold in the 00 zone or is the actual temperature just as good as in the other zones. If it is as good as other zones then the display is faulty, while if it s colder and freezing then the thermostat is faulty (I dont think so). If the temp is fine by you then do not worry about the display/LCD. You can replace it when you occupy the premises next. While if the temp is really closer to 00 then the thermostat needs replacement.
Posted on Sep 26, 2010
This .pdf file may be of help to you:
www.brivis.com.au/.../Carrier%20Comfort%20Zone%20II%20Owner's%20Guide.pdf
Perhaps you could get some help from Carrier Support here:
http://www.residential.carrier.com/support/index.shtml
I noticed they have an option of talking to an engineer, and perhaps they could explain how to reset or set the unit.
Hope this helps.
Posted on Sep 25, 2010
I've read the pdf manual a few times; no where does it talk about a 00 "zero-zero" ambient temp display. I had also gone to the Carrier site and filled out that questionaire form; since it's a Saturday, I figured I would not hear anything from Carrie until sometime Monday...
thanks for those "suggestions", but I had already done those steps.
