GE (PSS26MSRSS) Side by Side Refrigerator Logo
Anonymous Posted on Sep 25, 2010
Wiring on the bottom of the ice and water door broke front control panel don't work but frig runs fine
Anonymous
Level 3:
  • Master 3,600 Answers
  • Posted on Sep 25, 2010
Anonymous
Master
Level 3:
Answers
3600
Questions
Helped
1575024
Points
11774
You can order the parts to fix this yourself if you are handy with tools. You would need to unplug the refrigerator to do this I will supply you with a parts store you can buy parts from and will give you a parts list that yu can look at and decide what you need. Of course I would turn off the water before continuing to use this refrigerator. here is the site and put you model number in and it will give you a parts list to look at. I can't help you anymore without having the Model number. Thanks for using fix-ya and if you need more help please reply back with any other questions you need help with. www.appliancepartspros.com
2answers
I just connected the ice maker water line to the unit. The Frig has electrical power and ice is making. My problem is that the controls at the front of the Frig is not working. I cannot dispense the ice...
Without a model number here how they usually operate. The DOOR / LIGHT switch disables water and ice in door functions. I.e. it is not supposed to operate with the door open. If the switch is open... i.e the light is not working door open, (Switch has 2 functions Light and Water / ive in door operation) Then the control panel / water / ice in door will all not work either. It is possible for the light to work while the CP / H2o / Ice do not work. Usually if a door switch fails the light stops working also. It is not always the case.
Try holding to door switch plunger depressed and see if your CP works and water in door work. DO NOT try ice in door as you can damage things.
If you respond with a model number and brand; I will see what I can dig up for you use while troubleshooting your unit. Expect to see parts data also.
Thanks for choosing FixYa,
Kelly
Water is leaking from bottom of frig, supply line is fine. Its seems to be comming from the front end of frig
Check the drains. It may have been clogged by particles from the food accumulated over time. It may also be from the ice that may have accumulated inside, at the panel at the back.
2answers
On humid days water puddles in the bottom of the frig.
Sounds like the door is not closing properly so humid air is coming into the fridge OR door not closing properly and the humid air is condensing around the door so it is leaking the condensation OR
The water from the defrost cycle is not evaporating so it overflows from the evaporator pan above the compressor. You better call a service technician before getting some floor damage (Do not call A&E)
1helpful
Kitchenaid side by side frig (KSCS25IN) will not dispense cubes
Check the drive gear for the agitator, It might have gotten stuck on ice too many times and stripped the gear. Good luck!
2answers
Water dispenser will not work when lever is pressed. we had an intermittent problem with it before it stopped working altogather.I was going to look at it but was afraid to pop off the trim on the outside...
This could be a bad water valve in the frig. This frig has a double water valves. One for the ice maker and one for the water dispenser. It should be in the lower back. Where the water line goes in. You can check this valve easily. Find the double water valve on the frig. Turn off water supply to frig first. Swap the plastic water lines going from the water valve into the frig. Turn water supply on. Then see if the water dispenser works. Sometimes you will have to operate the water dispenser for a little while to get the air out of the line. If it works now then the problem is in the water valve solenoid and needs to be replaced.
2answers
Black strip on front of wall between frig and freezer really hot
not supposed to be hot to touch, try pulling out refrig and vaccuming the coils, your probably FULL of dust and debris, also remove the kickplate from front and clean under there as well
Top Refrigerators Experts
vince
Johnny 1000
