Question about Whirlpool Freezers
The door on our older freezer was left open. 2days later I noticed it. The unit runs but comp hums but cooling coils are not getting cold them dial does not shut unit on and off. Without schematic I don't know if interior fan is on klickson. I am up for suggestions. Thanks Gary Teter
Posted by gdt760 on
geoff hunter
  • 4,793 Answers
Chance are that the frost has turned to ice if the unit started to defrost then got cold again.do a full defrost and then try starting from warm....
Posted on Sep 25, 2010
We have Frigidaire Upright Freezer. After 6-7 days its stops cooling as its condenser gets ice around it whereas the fan is working good. We clean the ice and it again starts working/cooling.
There are a few possibilities. Freeze-ups are a result of the unit either not having sufficient airflow or the compressor running too long and too often. As you note the fan is good, chances are airflow is not the issue. There are a few quick items that you can check on:
1. Check door seals. Leaks will cause the interior to lose cooling faster and result in compressor overloading.
2. Do not overload the freezer. Too much inside the freezer will cause loss of airflow INSIDE the unit and can cause issues.
3. Avoid putting too much unfrozen material into the freezer at once. It takes a lot of work to remove all the heat from a large amount of material.
4. Avoid multiple opening and closing of the door. Upright freezers are inefficient as they lose all their cold air as soon as you open the door. Chest freezers do better if you must go into the unit often.
Lastly, undercharged refrigerant system can cause the same issue. If you don't have any of the other problems noted, have a serviceman check the refrigerant and fill the system as needed.
Feb 29, 2016 | Frigidaire Freezers
Frigidair FFU21C3AW1 cooling slowly
When it comes to freezer units, there is not much one can do on their own. You can try to move it around and clean any debris from underneath and behind it. You can see if the internal temperature matches what you have it set on, and then you'll need to contact a professional to diagnose the actual sealed system of the unit.
Jul 17, 2012 | Frigidaire 21 cu. ft. / 595 liter Upright...
Very hot to touch compressor, is it safe?
Compressors do usually get a bit warm during operation, but unless you left the door open for an extended period, or cooled warm foods in your freezer, the compressor would periodically run, then stop and cool off. If you observe your refrigerator for a while and notice that it is running much more than usual, it may to be serviced, possibly to look for a coolant leak or other similar issue.
May 17, 2011 | Frigidaire Freezers
I have a Artic Air White Reach In Freezer. It is not blowing cold air from he top where the cold air comes in. Freezer was at 60 degrees F. I turned the defrost switch to make sure it wasn't in...
Is the freezer itself getting cold.To blow cold air.the freezer should get cold/friezed.the cold air blows from freezer to fridge side.first the freezer side gets cold, then when the freezer side gets enough cool to its set cooling temperature, at that time the defrost cycle starts.In defrost cycle the fan in the freezer starts running and the cool air from freezer starts going to fridge side.There is a ventilation passage between fridge and freezer from where this cool air passes.---------------- If in your case, the freezer is getting proper cold, but its not blowing cold air from freezer to fridge, then possibility is that, there is a blockage in ventilations.But if ventilation its clear, then its defrost problem.First try manual defrost reset procedure. The procedure is as follows: ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. ------------------------- BUT if in your case, the freezer section itself is not getting cold, then the problem is compressor related.The compressor is the part which cools the freezer frost.In the compressor, there is a refrigerant to cool the freezer.If the compressor gets weak or the refrigerant gets low, then it will not cool the freezer, if the freezer is not cool then it will blow warm air from freezer to fridge, in defrost cycle.In that case, the compressor is faulty and its the cause of problem.------------ So you will have to first check , that is your freezer getting cold or not.as per that you can start the troubleshooting.------------------
You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
May 01, 2011 | Arctic Air Freezers
Motor/compressor hums but does not run. is there a reset button on this unit?
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 04, 2010 | Frigidaire 9 cu. ft. / 255 liter Chest...
Side byrefrigerator runs but not cold. Freezer is
take everything out of it, and let it thaw for 24 hours, using towels and whatever to clean up the water......then plug it back in, if it still does it, like 2 days later, it's broke, if it doesn't it was just the coil in the back that froze up. Happened to me.
Feb 15, 2010 | Whirlpool Freezers
I own a Frigidaire Upright Freezer/not freezing...
Good day,
If the unit is running but not cooling then check the following.
1. The fan motor behind the rear panel is not running, you will have to remove the panel, being careful not to damage the control thermostat, and inspect the motor, and replace if needed.
2. The defrost system has failed, icing the coil behind that same panel, and not circulating air. There are 3 parts to the defrost system, the main heater, a calrod unit mounted on the bottom of the cooling coil, a defrost control thermostat which is located on that same coil, but on the top. It is a small 1" round disk with 2 wires coming out of it.
Lastly, a timer which is located on the back of the machine and determines how often the unit defrosts.
If you have an ohm meter and know how to use it, you can test the heater and control thermostat for continuety if the coil is indeed iced up. If not iced up, the test will not work.
To test the timer, you take a screwdriver and with the machine on, turn the shaft clockwise until it shuts off. wait 35 minutes. If it turns the machine back on, it's O.K. If not, it needs replaced.
A tutorial on defrost systems is at the end of this post.
3. If none of the above work, then it is in the compressor/sealed system. This machine has had many issues in this area and is a serious problem unless...........
The unit is under 5 years of age, then warranty will cover the repair.
http://www.appliance411.com/faq/howdefrostworks.shtml
Thank you for using FixYa
Jan 14, 2010 | Frigidaire Freezers
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
Freezer Thawing Out
This will not cause a freon leak and it is possible that the door was left open, but to be certain that you don't have a defrost issue, follow the guide below to diagnose any problems. Also the warm walls are normal during compressor run times.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/0047_3.asp
If your freezer cools but doesn't get cold enough, it may have a problem in one of several areas. To better understand the proper operation of a freezer, read about freezers in the How Things Work section of our website.
In a self-defrosting freezer, poor cooling often results from a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel inside your freezer. But if you see any frost or ice build-up on the inside walls, ceiling, or floor of your freezer, it's a sure sign of frost build-up. And that's a sign of a problem with the self-defrosting system.
Freezers should self-defrost three to four times in 24 hours. But if a component in the self-defrosting system fails, the freezer continues to try to cool, instead. Eventually, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There's still some cooling because the coils are frozen. But with no air flow over the coils, the cooling is quite limited and the freezer isn't as cold as it needs to be.
An easy (though often inconvenient) test of whether the problem is with the self-defrosting system is to remove all of the perishable food from the freezer, turn the thermostat to Off, and leave the door open for 24 to 48 hours. (Keep several towels handy in case the melting frost and ice overflows the drip pan). This "manually" defrosts the freezer. When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the freezer then cools properly, it indicates a problem with one of these components in the self-defrosting system:
  • The defrost timer. To test this, manually advance to the defrost cycle. The unit should advance itself out of the defrost cycle in about 45 minutes.
  • The defrost thermostat (or bi-metal switch). This thermostat allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees (depending on its design). This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on.
  • The defrost heater. You can test this for continuity using an electrical meter.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 19, 2008 | Frigidaire Freezers
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Freezers Logo
71 people viewed this question
Top Whirlpool Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Jim
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
