https://chemicalwiki.com/wood-glue/
If you have the money, there are plenty of products on the market that offer excellent protection for your home, but are being used primarily for home improvement stores. You will have to be careful to read the labels on these products, to make sure that they contain no Resurfacer. If you have the money, then go for a product that has a higher price range, but the product is as strong as possible. At the same time, if you can afford a little less, then be careful to buy a quality product, because the last thing you want is to buy a product that cannot bond to your wood. While there are many very affordable brands of products, some of the more expensive ones may not be as strong as their cheaper cousins and may not have the Resurfacer. Some of the cheaper products may also contain Formaldehyde, which again, may have to be listed as a carcinogen, and may cause harm to your family. So the best glue for bonding wood to wood is not really the spray you use to stick a piece of plywood down, but something that contain Resurfacer. While it is not a completely "green" product, it is as green as the best alternatives that you can get, and is the next best thing to a self-healing product. How can you use wood glue to make slime? You are probably thinking that using wood glue to make slime will mean using lard, fat or grease. Don't worry - it's not the same as the stuff they use in sausage making! Lard and fat are simple glues, not strong enough to hold the weight of a wood plank. Wood glue is usually made from natural ingredients such as beeswax, gelatin, and/or mineral oil. Wood glue can be used to glue anything together, from wood to concrete to metal, paper to cardboard. Remember, when making any type of final product, whether for personal use or for commercial uses, it is important to follow all safety guidelines. Look for the ABC's of wood glue safety: Never apply glue to your skin. Allergic reactions to wood glue can happen quickly and easily. If you're going to be painting or gluing something over a color, be sure to first test the color on a piece of fabric before attempting to stick the item to your skin. Having a second color on hand could save you from potential mishaps. As with any other type of glue, if you are unsure if the item you are working with is food grade, don't use it. You could be putting someone's life at risk. They have all the signs of food grade material; these include:
