You generally have a weak capacitor in the power supply, that will delay a startup! Second to these are poor grounds on any and all ICs attached to heat sinks. A heat sink is a large metal piece mounted on the TV board. It is a cooling fin to reduce heat on the IC. The pins are underneath these, and will have cracked rings around them. These of course reduce voltage and a promote a slow startup. Please check all capacitors with a capacitor checker and look closely underneath the TV board for bad solder grounds and resolder!
