Question about Sony DVP-NC85H Multi-disc DVD Player
Disc is stuck on playhead, won't come out on carousel.
Posted by ke6n on
  • Sony Master
  • 17,130 Answers
No way but to open the cover the mechanism and remove from the drive of the mechanism.
If the power is present, then check the loading motor drive mechanism , checkthe drive IC for fault.
If not check the power from the SMPS and rectify.
If not the board can be faulty.
Posted on Sep 25, 2010
Stuck Sony CDP-CX355 Carousel CD player - door won't open, just hums
Something must be jammed so a trip to a Technician will resolve that. This is one of the reason I never buy changers of any kind because over the years I have had to fix so many cartridge, platter and other changers that are all designed poorly enough to make the 90 day period but not last too much longer. The Sony ES models are the best but they were big money back then- I have a broken one in my shop now.
Jan 23, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
My Kodak Carousel 650H has a stuck slide and the tray won't move. The stuck slide is lined up with the "gate index." I tried releasing the tray but only one side of the tray releases. The...
Two steps.
1) Look down into the center of the carousel. There should be a round, flat silver knob with an elongated notch in it. Take a coin (US 5-cent piece or similar) and use it to turn the knob. This releases the catch on the metal plate under the projector. You should then be able to lift the carousel off. Be careful: some slides will fall out as the slot is not aligned with the carousel body properly once you do this.
2) Make sure the locking ring on top of the carousel is in place (or else take out all your slides. Turn the carousel over and gently rotate the metal plate covering the bottom of the carousel into position. You will hear/feel a "click" when it's in place.
The projector may have jammed because there are two slides stuck in the viewing slot--check for this before you put the carousel back on the projector. If it jams a lot the metal plate under the carousel may be bent.
Jul 17, 2011 | Kodak Carousel 4600 Slide Projector
Jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
May 01, 2009 | Sony CDP-C265 CD Player
A cd has gotten stuck in my Sony 5 cd/dvd carousel player. Appears that the label on the CD had gotten soft (sticky) and when the carousel rotates it stays stuck underneth the top while the carousel moves...
As long as the cd hasn't caused any other damage to the electronics or mechanics of the player, it should be an easy fix. First, open your carousel then unplug the player to avoid shock. Remove the top lid of the player via the screws on the exterior holding it in place. From there, the stuck CD should be right there for you to reach in and remove. Hope this helps!
Mar 24, 2009 | Sony CDP-CE375 5-Disc CD Changer
Carousel out of alignment
Instructions are in the service manual to do the pop-up and table sensor adjustment but when the mechanism starts to grab a disc it has already locked onto to a slot. I don't think it possible with the lockpins on the turntable to get stuck between two slots the spacing is just to tight.
Feb 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Jan 04, 2009 | Onkyo DX-C380 6-Disc CD Changer
COMPACT DISC PLAYER
Please update this with the make and model so I can assist.
Thanks,
Dan
May 23, 2008 | Sony Audio Players & Recorders
Cd stuck in
take the cover off and take the CD out
Oct 06, 2006 | Onkyo DX-C390 6-Disc CD Changer
Sony DVP-NC85H Multi-disc DVD Player Logo
66 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
